주요 콘텐츠로 건너뛰기
D-Link DCS-5222L WiFi Antenna Replacement
필요한 것
  1. D-Link DCS-5222L WiFi Antenna Replacement, WiFi Antenna: 1 단계, 이미지 1/3 D-Link DCS-5222L WiFi Antenna Replacement, WiFi Antenna: 1 단계, 이미지 2/3 D-Link DCS-5222L WiFi Antenna Replacement, WiFi Antenna: 1 단계, 이미지 3/3
    • Locate and remove the four rubber feet on the bottom of the camera using your fingers or a pair of tweezers.
  2. D-Link DCS-5222L WiFi Antenna Replacement: 2 단계, 이미지 1/2 D-Link DCS-5222L WiFi Antenna Replacement: 2 단계, 이미지 2/2
    • Using a #1 Phillips screwdriver, remove the four 7mm screws that are exposed by the removed feet.
  3. D-Link DCS-5222L WiFi Antenna Replacement: 3 단계, 이미지 1/2 D-Link DCS-5222L WiFi Antenna Replacement: 3 단계, 이미지 2/2
    • Using your hands, open the camera body by wiggling the bottom free from the upper shell.
    • Open the shell carefully, as the motherboard is attached to the bottom of the body; all of the components in the upper body are accordingly connected to the bottom. Likewise, the WiFi antenna is mounted to the upper shell, but a wire connects it to the motherboard on the bottom of the body.
  4. D-Link DCS-5222L WiFi Antenna Replacement: 4 단계, 이미지 1/2 D-Link DCS-5222L WiFi Antenna Replacement: 4 단계, 이미지 2/2
    • Using your soldering iron, heat the antenna contacts on the motherboard until the wire releases.
    • Soldering Irons are hot and can burn you and ignite flammable materials.
  5. D-Link DCS-5222L WiFi Antenna Replacement: 5 단계, 이미지 1/2 D-Link DCS-5222L WiFi Antenna Replacement: 5 단계, 이미지 2/2
    • Pinch the WiFi antenna's clip mount inside the upper part of the body with blunt ended tweezers while pulling the antenna from the outside.
결론
Ryan Null
회원 가입일: 10/26/18
377 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S2-G5, Peak Fall 2018 UMass Dartmouth, Team S2-G5, Peak Fall 2018 회원
UMASSD-PEAK-F18S2G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 14
전체 시간: 1,093
