주요 콘텐츠로 건너뛰기
D-Link DCS-825L Back Casing Replacement
필요한 것
  1. D-Link DCS-825L Back Casing Replacement, Accent Ring: 1 단계, 이미지 1/1
    • Grasp the side of the accent ring. There is a notch that your thumb will be able to grab ahold of.
  2. D-Link DCS-825L Back Casing Replacement: 2 단계, 이미지 1/1
    • Twist the accent ring until it pops off. You may need to use both hands if the accent ring is stuck.
  3. D-Link DCS-825L Back Casing Replacement: 3 단계, 이미지 1/1
    • Replace your accent ring with whichever color you choose.
  4. D-Link DCS-825L Back Casing Replacement, Back Casing: 4 단계, 이미지 1/2 D-Link DCS-825L Back Casing Replacement, Back Casing: 4 단계, 이미지 2/2
    • Remove one Phillips #2 screw from each side of the camera lens.
  5. D-Link DCS-825L Back Casing Replacement: 5 단계, 이미지 1/3 D-Link DCS-825L Back Casing Replacement: 5 단계, 이미지 2/3 D-Link DCS-825L Back Casing Replacement: 5 단계, 이미지 3/3
    • Pull the Wi-Fi Baby Camera open.
    • It should be easily done after the screws are removed.
  6. D-Link DCS-825L Back Casing Replacement: 6 단계, 이미지 1/2 D-Link DCS-825L Back Casing Replacement: 6 단계, 이미지 2/2
    • Take your tweezers and gently pull the white tip out from its plug that is connected to a red and black twisted wire.
  7. D-Link DCS-825L Back Casing Replacement: 7 단계, 이미지 1/3 D-Link DCS-825L Back Casing Replacement: 7 단계, 이미지 2/3 D-Link DCS-825L Back Casing Replacement: 7 단계, 이미지 3/3
    • Take your tweezers and gently pull the white tip that is on the end of the white wire (the antenna) out from its plug in.
결론
April Ulrich
회원 가입일: 10/09/18
205 평판
안내서 2개 작성하였습니다
USF Tampa, Team S1-G5, Leahy Fall 2018 USF Tampa, Team S1-G5, Leahy Fall 2018 회원
USFT-LEAHY-F18S1G5
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 387
