주요 콘텐츠로 건너뛰기
D-Link DCS-825L LED Light Cover Replacement
필요한 것
  1. D-Link DCS-825L LED Light Cover Replacement, Accent Ring: 1 단계, 이미지 1/1
    • Grasp the side of the accent ring. There is a notch that your thumb will be able to grab ahold of.
  2. D-Link DCS-825L LED Light Cover Replacement: 2 단계, 이미지 1/1
    • Twist the accent ring until it pops off. You may need to use both hands if the accent ring is stuck.
  3. D-Link DCS-825L LED Light Cover Replacement: 3 단계, 이미지 1/1
    • Replace your accent ring with whichever color you choose.
  4. D-Link DCS-825L LED Light Cover Replacement, Back Casing: 4 단계, 이미지 1/2 D-Link DCS-825L LED Light Cover Replacement, Back Casing: 4 단계, 이미지 2/2
    • Remove one Phillips #2 screw from each side of the camera lens.
  5. D-Link DCS-825L LED Light Cover Replacement: 5 단계, 이미지 1/3 D-Link DCS-825L LED Light Cover Replacement: 5 단계, 이미지 2/3 D-Link DCS-825L LED Light Cover Replacement: 5 단계, 이미지 3/3
    • Pull the Wi-Fi Baby Camera open.
    • It should be easily done after the screws are removed.
  6. D-Link DCS-825L LED Light Cover Replacement: 6 단계, 이미지 1/2 D-Link DCS-825L LED Light Cover Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Take your tweezers and gently pull the white tip out from its plug that is connected to a red and black twisted wire.
  7. D-Link DCS-825L LED Light Cover Replacement: 7 단계, 이미지 1/3 D-Link DCS-825L LED Light Cover Replacement: 7 단계, 이미지 2/3 D-Link DCS-825L LED Light Cover Replacement: 7 단계, 이미지 3/3
    • Take your tweezers and gently pull the white tip that is on the end of the white wire (the antenna) out from its plug in.
  8. D-Link DCS-825L LED Light Cover Replacement, LED Light Cover: 8 단계, 이미지 1/1
    • Grab the white cylinder with your thumb and index finger.
  9. D-Link DCS-825L LED Light Cover Replacement: 9 단계, 이미지 1/1
    • Gently lift the cylinder up from its placement in your Wi-Fi Baby Camera.
  10. D-Link DCS-825L LED Light Cover Replacement: 10 단계, 이미지 1/1
    • Remove the white cylinder completely to replace it.
결론
Annalise Leclair
회원 가입일: 10/09/18
97 평판
안내서 1개 작성함
USF Tampa, Team S1-G5, Leahy Fall 2018 USF Tampa, Team S1-G5, Leahy Fall 2018 회원
USFT-LEAHY-F18S1G5
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 317
