소개
LED lights are the lights on your device that turn on to send you different messages about the functioning of your electronic router. If the LED lights on your D-Link router are fading, inconsistent, or completely off at the power up of your device, replacement may be necessary. This step-by-step instructional guide will help you do just that.
필요한 것
Begin by placing the wired router face down.
Locate the two black plastic screw coverings at the top of the device and remove them with your fingers.
Use a plastic opening tool between the edges of the router and gently pry the device apart.
Release the clips as you work your way around the device to avoid breaking them.
Separate the front and back case of the router.
Once you have removed the top black case of the router, remove the silver casing surrounding the logic board.
Use a Phillips #2 screwdriver to remove the two screws at the bottom of the motherboard.
Now that you have removed all screws and the surrounding silver casing, pop the logic board out from the bottom component of the router.
You have now removed the logic board from your device.
Locate the problematic LED light on the motherboard.
Using a plastic opening tool, very gently tilt its black base backwards.
Using your soft finger, tilt the LED light base backwards so that the actual light is facing upside down, at a 180 degree angle from the others.
With a pair of tweezers, gently pry the LED light back and forth between its connecting wires until it is able to be removed.
You should now have a removed LED light, ready to be replaced with a new one.
