주요 콘텐츠로 건너뛰기
D-Link EBR-2310 Motherboard Replacement
필요한 것
  1. D-Link EBR-2310 Motherboard Replacement, Remove Plastic Screw Coverings: 1 단계, 이미지 1/1
    • Begin by placing the wired router face down.
    • Locate the two black plastic screw coverings at the top of the device and remove them with your fingers.
    • The two bottom plastic screw coverings do not need to be taken off.
  2. D-Link EBR-2310 Motherboard Replacement, Remove Screws: 2 단계, 이미지 1/1
    • Using a Phillips #2 screwdriver, remove the two top screws.
  3. D-Link EBR-2310 Motherboard Replacement, Pry Open The Router: 3 단계, 이미지 1/1
    • Use a plastic opening tool between the edges of the router and gently pry the device apart.
    • Release the clips as you work your way around the device to avoid breaking them.
    • Separate the front and back case of the router.
  4. D-Link EBR-2310 Motherboard Replacement, Remove Silver Casing: 4 단계, 이미지 1/2 D-Link EBR-2310 Motherboard Replacement, Remove Silver Casing: 4 단계, 이미지 2/2
    • Once you have removed the top black case of the router, remove the silver casing surrounding the logic board.
    • It should easily snap out of place.
  5. D-Link EBR-2310 Motherboard Replacement, Remove Inner Bottom Screws: 5 단계, 이미지 1/2 D-Link EBR-2310 Motherboard Replacement, Remove Inner Bottom Screws: 5 단계, 이미지 2/2
    • Use a Phillips #2 screwdriver to remove the two screws at the bottom of the motherboard.
  6. D-Link EBR-2310 Motherboard Replacement, Remove Bottom Case: 6 단계, 이미지 1/1
    • Now that you have removed all screws and the surrounding silver casing, pop the logic board out from the bottom component of the router.
    • You have now removed the logic board from your device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jessica
회원 가입일: 09/19/14
428 평판
안내서 3개 작성하였습니다
USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014 USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014 회원
USFSM-STEWART-F14S1G4
4 회원들
안내서 19개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 20
전체 시간: 839
