주요 콘텐츠로 건너뛰기
D-Link HD Wi-Fi Camera Camera Lens Replacement
필요한 것
  1. D-Link HD Wi-Fi Camera Camera Lens Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Place the camera upwards between your thumb and first finger.
    • Tilt the camera to the best position and loosen the captive linings using a plastic opening tool.
    • Slide the top cover outwards to separate the upper section from the lower lid using the plastic opening tool.
  2. D-Link HD Wi-Fi Camera Camera Lens Replacement: 2 단계, 이미지 2개 중 1개 D-Link HD Wi-Fi Camera Camera Lens Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the 6.0mm Phillips #00 screws that secure the back cover to the inner frame.
    • Lift the rear lid upwards using your fingers and separate it from the internal components and motherboard.
  3. D-Link HD Wi-Fi Camera Camera Lens Replacement: 3 단계, 이미지 2개 중 1개 D-Link HD Wi-Fi Camera Camera Lens Replacement: 3 단계, 이미지 2개 중 2개
    • Unscrew the motherboard from the frame. There are 3 Phillips #00 5.0mm screws holding it in place.
    • Then (gently!) remove the motherboard and the lens with your fingers.
  4. D-Link HD Wi-Fi Camera Camera Lens Replacement, Camera Lens: 4 단계, 이미지 2개 중 1개 D-Link HD Wi-Fi Camera Camera Lens Replacement, Camera Lens: 4 단계, 이미지 2개 중 2개
    • Make sure your hands are dry and you are working in a dry area. To prevent damage, do not touch the lens.
    • There are two Phillips #00 6.0mm screws keeping the camera in place. Remove the screws first.
    • Gently unplug the camera from the motherboard, and remove the camera.
결론
작성자
1다른 기여자 명과 함께
Morgen Jaques
회원 가입일: 09/28/17
557 평판
안내서 5개를 작성함
1가이드 댓글
How do I get hold of a replacement lens? Can’t seem to find anyone selling them. Need one for a DCS-2670L
Paul Williams - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 16
전체 시간: 1,421
