주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. D-link DI-524 수리는 저희 서비스 설명서를 사용하십시오.
  1. D-link DI-524 Teardown, Overview: 1 단계, 이미지 1/3 D-link DI-524 Teardown, Overview: 1 단계, 이미지 2/3 D-link DI-524 Teardown, Overview: 1 단계, 이미지 3/3
    • This is the router, in all of its 12 year old glory.
  2. D-link DI-524 Teardown, Opening it up: 2 단계, 이미지 1/3 D-link DI-524 Teardown, Opening it up: 2 단계, 이미지 2/3 D-link DI-524 Teardown, Opening it up: 2 단계, 이미지 3/3
    • First of, remove the antenna by simply unscrewing it.
    • With that done, flip the router over and remove the 2 screws marked out in orange (pic 2).
    • Then simply flip the router back over and lift up the top plastic.
  3. D-link DI-524 Teardown, Removing the board: 3 단계, 이미지 1/3 D-link DI-524 Teardown, Removing the board: 3 단계, 이미지 2/3 D-link DI-524 Teardown, Removing the board: 3 단계, 이미지 3/3
    • With the plastic removed, we get a look at the board itself. Now remove the two other screws at the back (also marked out in orange).
    • Before being able to lift the whole board out, you will also have to unscrew a nut where the antenna was attached to. This can easily be done with a pair of pliers.
    • With that done, simply pull the connector out and lift the border 'up and out'.
  4. D-link DI-524 Teardown, The chips: 4 단계, 이미지 1/3 D-link DI-524 Teardown, The chips: 4 단계, 이미지 2/3 D-link DI-524 Teardown, The chips: 4 단계, 이미지 3/3
    • This is simply a better look at the board chips. If anone reading this knows specifically what they are, feel free to comment and I will add the information.
    • (There is also one more chip but Ifiixit allows only 3 pictures)
  5. D-link DI-524 Teardown, The lone metal clip: 5 단계, 이미지 1/2 D-link DI-524 Teardown, The lone metal clip: 5 단계, 이미지 2/2
    • The last piece of the router is this small metal clip here. Simply pull it up.
  6. D-link DI-524 Teardown, Thats it!: 6 단계, 이미지 1/1
    • You have successfully taken apart a D-link DI-524.
    • I was unable to remove anything more from the mother board as it is all soldered on.
Imad Knight
회원 가입일: 07/11/16
1,429 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 5
전체 시간: 2,550
