소개
I phoned D-Link tech support several times, and they eventually concluded my device was broken, but I got it fixed.
My D-Link dhp w306av would do nothing but blink it's blue (WPS/ENY) LED. None of the support people could fix it with any kind of reset. This is what I managed to do.
  1. (With router unpluged, and no ethernet cable attched) Turn the router on (push in the power button on the side) remember it's not plugged into the wall yet.
    • (With router unpluged, and no ethernet cable attched) Turn the router on (push in the power button on the side) remember it's not plugged into the wall yet.
  2. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  3. Take a pin or micro screwdriver and push in and hold the reset button.
    • Take a pin or micro screwdriver and push in and hold the reset button.
    • Still holding the reset button plug the router into a power outlet.
    • Keep holding down the reset button for at least 15 seconds.
    • If you have the same luck I did your green lights on the side will start to cycle and light up.
    • Now you can go back to your quick install guide that came with the router and set it up again.
결론
hope it works for you
다른 4명이 해당 안내서를 완성하였습니다.
alan
회원 가입일: 2013년 08월 23일
212 평판
안내서 1개 작성함
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 24
지난 30일: 101
전체 시간: 4,657
