주요 콘텐츠로 건너뛰기
D-link PowerLine Hard Reset
필요한 것
  1. D-link PowerLine Hard Reset, D-link PowerLine Hard Reset: 1 단계, 이미지 1/1
    • (With router unpluged, and no ethernet cable attched) Turn the router on (push in the power button on the side) remember it's not plugged into the wall yet.
  2. D-link PowerLine Hard Reset: 2 단계, 이미지 1/1
    • Take a pin or micro screwdriver and push in and hold the reset button.
    • Still holding the reset button plug the router into a power outlet.
    • Keep holding down the reset button for at least 15 seconds.
    • If you have the same luck I did your green lights on the side will start to cycle and light up.
    • Now you can go back to your quick install guide that came with the router and set it up again.
결론
hope it works for you
다른 4명이 해당 안내서를 완성하였습니다.
alan
회원 가입일: 08/23/13
1 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 5,933
