주요 콘텐츠로 건너뛰기
DBPOWER RD-810 Fan Replacement
필요한 것
  1. DBPOWER RD-810 Fan Replacement, Top Cover: 1 단계, 이미지 1/2 DBPOWER RD-810 Fan Replacement, Top Cover: 1 단계, 이미지 2/2
    • Make sure the projector is unplugged before starting
    • Place the projector upside down to access the screws on the bottom.
    • Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
  2. DBPOWER RD-810 Fan Replacement: 2 단계, 이미지 1/1
    • Flip the projector over and then remove the cover by lifting it up.
  3. DBPOWER RD-810 Fan Replacement, Motherboard and LED Bulb: 3 단계, 이미지 1/3 DBPOWER RD-810 Fan Replacement, Motherboard and LED Bulb: 3 단계, 이미지 2/3 DBPOWER RD-810 Fan Replacement, Motherboard and LED Bulb: 3 단계, 이미지 3/3
    • Remove the three 6mm PH2 phillips head screws.
    • Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
  4. DBPOWER RD-810 Fan Replacement: 4 단계, 이미지 1/3 DBPOWER RD-810 Fan Replacement: 4 단계, 이미지 2/3 DBPOWER RD-810 Fan Replacement: 4 단계, 이미지 3/3
    • Disconnect the three wire connectors. Grasp both sides of the connector and pull apart.
    • Keep the connector parallel to the mother board to avoid breaking the solder connection.
    • Lift the motherboard up and place it out of the way.
  5. DBPOWER RD-810 Fan Replacement: 5 단계, 이미지 1/3 DBPOWER RD-810 Fan Replacement: 5 단계, 이미지 2/3 DBPOWER RD-810 Fan Replacement: 5 단계, 이미지 3/3
    • Remove the five 7mm PH2 phillips head screws on the black plate and lift the plate out.
    • Lift the aluminum heat sink up to remove it from the projector.
    • The motherboard is already removed in this step.
  6. DBPOWER RD-810 Fan Replacement, Fan: 6 단계, 이미지 1/1
    • Lift the fan up and out of the projector.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
John Russell
회원 가입일: 02/14/18
914 평판
안내서 9개 작성하였습니다
USF Tampa, Team S5-G3, Eyestone Spring 2018 USF Tampa, Team S5-G3, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S5G3
3 회원들
안내서 9개 작성하였습니다
댓글 2개
Wich cooler does fit ? I just bought the Projector and want to change the Fan because it is too loud
pr0mqu33nkill3r - 답글
Do you know the fan size / model? I bought one of these projectors but the fan is way to loud. I want to replace it for a quiet one
Luis - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 16
전체 시간: 710
