주요 콘텐츠로 건너뛰기
DBPOWER RD-810 Power Supply Switch Replacement
필요한 것
  1. DBPOWER RD-810 Power Supply Switch Replacement, Top Cover: 1 단계, 이미지 1/2 DBPOWER RD-810 Power Supply Switch Replacement, Top Cover: 1 단계, 이미지 2/2
    • Make sure the projector is unplugged before starting
    • Place the projector upside down to access the screws on the bottom.
    • Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
  2. DBPOWER RD-810 Power Supply Switch Replacement: 2 단계, 이미지 1/1
    • Flip the projector over and then remove the cover by lifting it up.
  3. DBPOWER RD-810 Power Supply Switch Replacement, Motherboard and LED Bulb: 3 단계, 이미지 1/3 DBPOWER RD-810 Power Supply Switch Replacement, Motherboard and LED Bulb: 3 단계, 이미지 2/3 DBPOWER RD-810 Power Supply Switch Replacement, Motherboard and LED Bulb: 3 단계, 이미지 3/3
    • Remove the three 6mm PH2 phillips head screws.
    • Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
  4. DBPOWER RD-810 Power Supply Switch Replacement: 4 단계, 이미지 1/3 DBPOWER RD-810 Power Supply Switch Replacement: 4 단계, 이미지 2/3 DBPOWER RD-810 Power Supply Switch Replacement: 4 단계, 이미지 3/3
    • Disconnect the three wire connectors. Grasp both sides of the connector and pull apart.
    • Keep the connector parallel to the mother board to avoid breaking the solder connection.
    • Lift the motherboard up and place it out of the way.
  5. DBPOWER RD-810 Power Supply Switch Replacement: 5 단계, 이미지 1/3 DBPOWER RD-810 Power Supply Switch Replacement: 5 단계, 이미지 2/3 DBPOWER RD-810 Power Supply Switch Replacement: 5 단계, 이미지 3/3
    • Remove the five 7mm PH2 phillips head screws on the black plate and lift the plate out.
    • Lift the aluminum heat sink up to remove it from the projector.
    • The motherboard is already removed in this step.
  6. DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Circuit: 6 단계, 이미지 1/3 DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Circuit: 6 단계, 이미지 2/3 DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Circuit: 6 단계, 이미지 3/3
    • Remove the two 9mm PH2 phillips head screws.
    • Lift the mirror behind the power supply circuit out to gain access to the circuit board.
  7. DBPOWER RD-810 Power Supply Switch Replacement: 7 단계, 이미지 1/2 DBPOWER RD-810 Power Supply Switch Replacement: 7 단계, 이미지 2/2
    • Lift the power supply circuit board out of the projector.
    • Disconnect the cable connector by pulling the two sides of the connector apart.
    • Keep the connector parallel to the circuit board to avoid breaking the solder connection.
  8. DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Switch: 8 단계, 이미지 1/3 DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Switch: 8 단계, 이미지 2/3 DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Switch: 8 단계, 이미지 3/3
    • Using the small plastic splunger, press in on the two latches on the sides of the power supply switch, then push it out of the case.
결론
John Russell
회원 가입일: 02/14/18
914 평판
안내서 9개 작성하였습니다
USF Tampa, Team S5-G3, Eyestone Spring 2018 USF Tampa, Team S5-G3, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S5G3
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 8
전체 시간: 166
