주요 콘텐츠로 건너뛰기
DBPOWER T20 Fan Replacement
필요한 것
  1. DBPOWER T20 Fan Replacement, DBPOWER T20 Disassembly: 1 단계, 이미지 1개 중 1개
    • Flip the device and lay flat.
  2. DBPOWER T20 Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the four (9 mm) screws with a PH2 screwdriver.
    • Remove the two (7 mm) located with a PH2 screwdriver.
  3. DBPOWER T20 Fan Replacement: 3 단계, 이미지 3개 중 1개 DBPOWER T20 Fan Replacement: 3 단계, 이미지 3개 중 2개 DBPOWER T20 Fan Replacement: 3 단계, 이미지 3개 중 3개
    • Flip the device over and pry the top off with a plastic opening tool.
  4. DBPOWER T20 Fan Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
  5. DBPOWER T20 Fan Replacement: 5 단계, 이미지 2개 중 1개 DBPOWER T20 Fan Replacement: 5 단계, 이미지 2개 중 2개
    • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
  6. DBPOWER T20 Fan Replacement: 6 단계, 이미지 3개 중 1개 DBPOWER T20 Fan Replacement: 6 단계, 이미지 3개 중 2개 DBPOWER T20 Fan Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
    • the black cable requires more force to remove than the other cables.
  7. DBPOWER T20 Fan Replacement: 7 단계, 이미지 2개 중 1개 DBPOWER T20 Fan Replacement: 7 단계, 이미지 2개 중 2개
    • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
  8. DBPOWER T20 Fan Replacement: 8 단계, 이미지 1개 중 1개
    • Raise motherboard by lifting sideways and then up to avoid the ports.
  9. DBPOWER T20 Fan Replacement: 9 단계, 이미지 2개 중 1개 DBPOWER T20 Fan Replacement: 9 단계, 이미지 2개 중 2개
    • Remove wires attaching the piezoelectric speakers to the motherboard.
  10. DBPOWER T20 Fan Replacement: 10 단계, 이미지 2개 중 1개 DBPOWER T20 Fan Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the five screws securing the black plastic cover with a J0 screwdriver.
    • Lift up and out to remove.
  11. DBPOWER T20 Fan Replacement, Fan: 11 단계, 이미지 2개 중 1개 DBPOWER T20 Fan Replacement, Fan: 11 단계, 이미지 2개 중 2개
    • Pull the fan up and out of the housing.
    • In this image the lamp and power input have been removed to increase visibility, you do not have to remove these to remove the fan.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Sebastian Alvarez de Araya
회원 가입일: 02/15/18
277 평판
안내서 1개를 작성함
USF Tampa, Team S16-G2, Boczar Spring 2018 USF Tampa, Team S16-G2, Boczar Spring 2018 회원
USFT-BOCZAR-S18S16G2
5 회원들
안내서 5개를 작성함
2가이드 댓글
Any idea of the specifications of the fan? 12v, 24v? I want to change it for another more quiet… but not sure about its voltage. It is 50x50x20mm right? Thanks!
Agustín Castiñeira Fernández - 답글
Hola! También querria sustituirlo por otro más silencioso. ¿Alguna idea de sus especificaciones?
Joan Abrines - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 10
전체 시간: 1,281
