주요 콘텐츠로 건너뛰기
DBPOWER T20 Lens Replacement
필요한 것
  1. DBPOWER T20 Lens Replacement, DBPOWER T20 Disassembly: 1 단계, 이미지 1개 중 1개
    • Flip the device and lay flat.
  2. DBPOWER T20 Lens Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the four (9 mm) screws with a PH2 screwdriver.
    • Remove the two (7 mm) located with a PH2 screwdriver.
  3. DBPOWER T20 Lens Replacement: 3 단계, 이미지 3개 중 1개 DBPOWER T20 Lens Replacement: 3 단계, 이미지 3개 중 2개 DBPOWER T20 Lens Replacement: 3 단계, 이미지 3개 중 3개
    • Flip the device over and pry the top off with a plastic opening tool.
  4. DBPOWER T20 Lens Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
  5. DBPOWER T20 Lens Replacement: 5 단계, 이미지 2개 중 1개 DBPOWER T20 Lens Replacement: 5 단계, 이미지 2개 중 2개
    • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
  6. DBPOWER T20 Lens Replacement: 6 단계, 이미지 3개 중 1개 DBPOWER T20 Lens Replacement: 6 단계, 이미지 3개 중 2개 DBPOWER T20 Lens Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
    • the black cable requires more force to remove than the other cables.
  7. DBPOWER T20 Lens Replacement: 7 단계, 이미지 2개 중 1개 DBPOWER T20 Lens Replacement: 7 단계, 이미지 2개 중 2개
    • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
  8. DBPOWER T20 Lens Replacement: 8 단계, 이미지 1개 중 1개
    • Raise motherboard by lifting sideways and then up to avoid the ports.
  9. DBPOWER T20 Lens Replacement: 9 단계, 이미지 2개 중 1개 DBPOWER T20 Lens Replacement: 9 단계, 이미지 2개 중 2개
    • Remove wires attaching the piezoelectric speakers to the motherboard.
  10. DBPOWER T20 Lens Replacement: 10 단계, 이미지 2개 중 1개 DBPOWER T20 Lens Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the five screws securing the black plastic cover with a J0 screwdriver.
    • Lift up and out to remove.
  11. DBPOWER T20 Lens Replacement, Lens: 11 단계, 이미지 1개 중 1개
    • The lamp does not need to be removed for this step to be preformed.
  12. DBPOWER T20 Lens Replacement: 12 단계, 이미지 1개 중 1개
    • Detach the keystone adjuster from the lens housing.
    • Lens is on a hinge so it should lift off easily, if it doesn't, adjust by swaying it forward or backward.
  13. DBPOWER T20 Lens Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the rubber foot and warranty sticker found underneath the device.
  14. DBPOWER T20 Lens Replacement: 14 단계, 이미지 2개 중 1개 DBPOWER T20 Lens Replacement: 14 단계, 이미지 2개 중 2개
    • Remove the two screws on the bottom of the device with a J0 screwdriver.
  15. DBPOWER T20 Lens Replacement: 15 단계, 이미지 1개 중 1개
    • Remove the focus-adjustment ring from the lens housing.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Andrea Espinosa
회원 가입일: 02/15/18
521 평판
안내서 3개를 작성함
USF Tampa, Team S16-G2, Boczar Spring 2018 USF Tampa, Team S16-G2, Boczar Spring 2018 회원
USFT-BOCZAR-S18S16G2
5 회원들
안내서 5개를 작성함
3가이드 댓글
How does the lens parts go together?
Lay - 답글
I need to know the same
Tremaine Mullins - 답글
Trying to put my lens back how to install
David Williams - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 19
전체 시간: 2,692
