주요 콘텐츠로 건너뛰기
DCC-3200 Charcoal Filter/Filter Basket Replacement
필요한 것
  1. DCC-3200 Charcoal Filter/Filter Basket Replacement, Charcoal Filter/Filter Basket: 1 단계, 이미지 1/1
    • Open lid
    • Take out the charcoal holder and open the capsule at the bottom.
    • The charcoal holder is located towards the back-left corner of the coffee maker.
  2. DCC-3200 Charcoal Filter/Filter Basket Replacement: 2 단계, 이미지 1/2 DCC-3200 Charcoal Filter/Filter Basket Replacement: 2 단계, 이미지 2/2
    • Replace the Charcoal filter with another one which can be purchased here
  3. DCC-3200 Charcoal Filter/Filter Basket Replacement: 3 단계, 이미지 1/1
    • Pull out the filter basket and see if there are any rips in the lining.
    • If so, use some nontoxic and waterproof adhesive on the open hole.
    • If the hole is too big or you don't want to glue it, you can purchase a new one on their website as well right here
결론
Hamad Khan
회원 가입일: 03/04/16
385 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 8-3, Botvin Spring 2016 UMass Dartmouth, Team 8-3, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G3
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 820
