필요한 것
Remove power cord, network cable, etc.
Remove paper tray and rear paper guide.
Slide the cover of the expansion slot backwards and open.
Unhook the flap from the lower hinge.
Loosen and remove front screws (1x top, 1x bottom) and rear (1x top, 1x bottom) with Phillips screwdriver.
Carefully loosen the front and rear housing parts with a light pull from the left.
Remove the left housing by carefully loosening the 3 clamps on the floor.
Follow the steps in reverse order to reassemble your device.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
