주요 콘텐츠로 건너뛰기
DJI Mavic Air 2 Battery Replacement
  1. DJI Mavic Air 2 Battery Replacement, Battery: 1 단계, 이미지 1/2 DJI Mavic Air 2 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Open the front arms of the drone by twisting the arms outward.
  2. DJI Mavic Air 2 Battery Replacement: 2 단계, 이미지 1/2 DJI Mavic Air 2 Battery Replacement: 2 단계, 이미지 2/2
    • Open the rear arms by extending the arms outwards.
  3. DJI Mavic Air 2 Battery Replacement: 3 단계, 이미지 1/2 DJI Mavic Air 2 Battery Replacement: 3 단계, 이미지 2/2
    • Press in each button on the sides of the battery.
  4. DJI Mavic Air 2 Battery Replacement: 4 단계, 이미지 1/1
    • While holding both buttons in, carefully remove the battery from its place in the drone.
    • The battery was missing in our device so we were unable to demonstrate this.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Troy Ventura
회원 가입일: 03/28/22
316 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team M-1, Gurgel Spring 2022 UMass Dartmouth, Team M-1, Gurgel Spring 2022 회원
UMASSD-GURGEL-S22SMG1
3 회원들
안내서 2개 작성하였습니다
댓글 한 개
N.Y.
Thanks to see you like ok and something rong out A/V UTF9-8e-mobile's new Jeddah the taime wthe you like the taime wth printt.alshhryabdu
I'm dron from DF and old the taime wth best man.😎😎😎😎🙆‍♂️📡
أناقة رجل - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 23
전체 시간: 1,143
