주요 콘텐츠로 건너뛰기
DJI Mavic Mini Battery Replacement
  1. DJI Mavic Mini Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 DJI Mavic Mini Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Orient the DJI Mavic Mini so that the camera faces away.
    • Use your finger to depress the lip on the panel until the lid becomes ajar.
    • Flip the panel up to expose the battery module.
  2. DJI Mavic Mini Battery Replacement: 2 단계, 이미지 2개 중 1개 DJI Mavic Mini Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Depress the locking mechanism on the battery module to release the lock.
    • Pull the battery straight out of the casing.
  3. DJI Mavic Mini Battery Replacement: 3 단계, 이미지 2개 중 1개 DJI Mavic Mini Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Check the battery pins on the DJI Drone for corrosion or warping. If either of these conditions are present, replacing the battery module may not help resolve the issue at hand.
    • Check the pin receptacles on the battery module for blockages.
    • Insert a new battery into the casing. Ensure that all connections are clean, unobstructed, and straight.
결론
Is your DJI Mavic Mini experiencing trouble with positioning, stability, or returning to home? Many of these problems an be due to weak signals or a faulty GPS. In this set of instructions, we will detail the removal process, inspection, and replacement of the DJI Mavic Mini GPS Module.
작성자
3다른 기여자 명과 함께
Cooper Schroeder
회원 가입일: 02/22/22
284 평판
안내서 2개를 작성함
Clemson, Team 1-2, Hunter Spring 2022 Clemson, Team 1-2, Hunter Spring 2022 회원
CLEM-HUNTER-S22S1G2
5 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 27
전체 시간: 1,525
