소개
This tutorial will show you how to prepare your DJI Mavic Mini drone for flight and connect it to the remote control.
Have fun!
Turn the rotor blades towards the battery compartment.
Grasp the cover tab with one finger, gently push it towards the camera and remove the cover.
Hold the drone with one hand and unfold the rotor arm with the other.
Repeat the process on the other side.
Turn the drone onto its back.
Fold out the rotor arm in an arc towards the battery compartment.
Repeat the process for the other rotor arm.
Stecke dein Handy in die Halterung und verbinde es per Kabel mit der Fernbedienung.Put your phone in the cradle and connect it to the remote control via cable.
Press the On button once briefly, release it, and then press and hold until you hear a "beep" sound.
Press the button on the bottom once briefly, let go, and then hold it down until you hear a "beep". (similar to the remote control).
Place the drone on a straight surface where it can take off.
With both devices turned on, open the "DJI Fly" app on your phone and wait for your drone to connect, you can tell because the app will show you a live image of your Drone.
Now when the drone is connected to the remote control, you can make it go up by pressing the "start" button in the app.
Have fun flying!
Work through the steps in reverse order to repack your drone.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
