주요 콘텐츠로 건너뛰기
DJI Mavic Mini GPS Replacement
필요한 것
  1. DJI Mavic Mini GPS Replacement, Battery: 1 단계, 이미지 1/2 DJI Mavic Mini GPS Replacement, Battery: 1 단계, 이미지 2/2
    • Orient the DJI Mavic Mini so that the camera faces away.
    • Use your finger to depress the lip on the panel until the lid becomes ajar.
    • Flip the panel up to expose the battery module.
  2. DJI Mavic Mini GPS Replacement: 2 단계, 이미지 1/2 DJI Mavic Mini GPS Replacement: 2 단계, 이미지 2/2
    • Depress the locking mechanism on the battery module to release the lock.
    • Pull the battery straight out of the casing.
  3. DJI Mavic Mini GPS Replacement: 3 단계, 이미지 1/2 DJI Mavic Mini GPS Replacement: 3 단계, 이미지 2/2
    • Check the battery pins on the DJI Drone for corrosion or warping. If either of these conditions are present, replacing the battery module may not help resolve the issue at hand.
    • Check the pin receptacles on the battery module for blockages.
    • Insert a new battery into the casing. Ensure that all connections are clean, unobstructed, and straight.
  4. DJI Mavic Mini GPS Replacement, GPS: 4 단계, 이미지 1/2 DJI Mavic Mini GPS Replacement, GPS: 4 단계, 이미지 2/2
    • Put your fingers against edge of the top case and begin undoing the connections at the edges first, then proceed to pry it open.
    • Alternatively, you may insert the iFixit opening tool between the top and bottom case first, and work your way around the perimeter to detach the top case.
  5. DJI Mavic Mini GPS Replacement: 5 단계, 이미지 1/1
    • With the internals exposed, locate the GPS board; this is the middle board component with a colored square located near the middle of the drone.
  6. DJI Mavic Mini GPS Replacement: 6 단계, 이미지 1/3 DJI Mavic Mini GPS Replacement: 6 단계, 이미지 2/3 DJI Mavic Mini GPS Replacement: 6 단계, 이미지 3/3
    • Remove the three 1.0 mm screws that form a triangle around the GPS board using the JIS #000 screwdriver.
    • Flip the GPS module over gently. Be mindful that it is attached to the device with a connector still.
  7. DJI Mavic Mini GPS Replacement: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use the ESD Safe Tweezers Blunt Nose tool to break apart the superglue connecting the cable to the GPS.
    • Repeat this for the superglue on the other side.
    • Detach the press-fit connecter from the GPS.
  8. DJI Mavic Mini GPS Replacement: 8 단계, 이미지 1/1
    • Remove the GPS from the drone.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Edward Ng
회원 가입일: 02/22/22
175 평판
안내서 1개 작성함
Clemson, Team 1-2, Hunter Spring 2022 Clemson, Team 1-2, Hunter Spring 2022 회원
CLEM-HUNTER-S22S1G2
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 58
전체 시간: 2,253
