주요 콘텐츠로 건너뛰기
DJI Mavic Mini Motherboard Replacement
필요한 것
  1. DJI Mavic Mini Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 DJI Mavic Mini Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Orient the DJI Mavic Mini so that the camera faces away.
    • Use your finger to depress the lip on the panel until the lid becomes ajar.
    • Flip the panel up to expose the battery module.
  2. DJI Mavic Mini Motherboard Replacement: 2 단계, 이미지 2개 중 1개 DJI Mavic Mini Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Depress the locking mechanism on the battery module to release the lock.
    • Pull the battery straight out of the casing.
  3. DJI Mavic Mini Motherboard Replacement: 3 단계, 이미지 2개 중 1개 DJI Mavic Mini Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Check the battery pins on the DJI Drone for corrosion or warping. If either of these conditions are present, replacing the battery module may not help resolve the issue at hand.
    • Check the pin receptacles on the battery module for blockages.
    • Insert a new battery into the casing. Ensure that all connections are clean, unobstructed, and straight.
  4. DJI Mavic Mini Motherboard Replacement, Motherboard: 4 단계, 이미지 3개 중 1개 DJI Mavic Mini Motherboard Replacement, Motherboard: 4 단계, 이미지 3개 중 2개 DJI Mavic Mini Motherboard Replacement, Motherboard: 4 단계, 이미지 3개 중 3개
    • Remove the four 5 mm screws that hold the upper panel using using the J000 screwdriver.
    • Orient the back of the DJI Mavic Mini towards you. Open the battery hatch using the iFixit opening tool to pry open the top panel at the seams.
    • Remove the two 5 mm screws that hold the bottom panel using using the J000 screwdriver.
  5. DJI Mavic Mini Motherboard Replacement: 5 단계, 이미지 2개 중 1개 DJI Mavic Mini Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Orient the bottom of the DJI Mavic Mini towards you.
    • Remove the bottom panel by inserting the iFixit Opening Tool into the edge of the bottom case.
    • Insert multiple picks in the seam around the perimeter to prevent the bottom panel from closing back up, then pry it open.
  6. DJI Mavic Mini Motherboard Replacement: 6 단계, 이미지 3개 중 1개 DJI Mavic Mini Motherboard Replacement: 6 단계, 이미지 3개 중 2개 DJI Mavic Mini Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Remove three 5 mm screws using the J000 screwdriver.
    • Remove the radiator to reveal the main board.
  7. DJI Mavic Mini Motherboard Replacement: 7 단계, 이미지 3개 중 1개 DJI Mavic Mini Motherboard Replacement: 7 단계, 이미지 3개 중 2개 DJI Mavic Mini Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • When removing the motherboard, don't wipe any thermal paste off of it. This will cause the drone to overheat.
    • Using the ESD Safe Blunt NoseTweezers, carefully remove the glue that holds the cable connectors to the main board, ensuring that you do not scratch the main board. Detach the connectors.
  8. DJI Mavic Mini Motherboard Replacement: 8 단계, 이미지 3개 중 1개 DJI Mavic Mini Motherboard Replacement: 8 단계, 이미지 3개 중 2개 DJI Mavic Mini Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • Disconnect the remaining cables and antennas from the main board by prying them up using the ESD Safe Blunt Nose Tweezers.
    • Using the J000 screwdriver, remove the remaining two 5 mm screws that are holding the motherboard down.
    • Remove the motherboard from the DJI Mavic Mini.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Logan Wake
회원 가입일: 02/22/22
184 평판
안내서 1개를 작성함
Clemson, Team 1-2, Hunter Spring 2022 Clemson, Team 1-2, Hunter Spring 2022 회원
CLEM-HUNTER-S22S1G2
5 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 37
전체 시간: 3,498
