소개
This guide will show you how to replace a DJI Mavic Mini propeller. Damaged propellers are common, as they may be damaged in flight. This guide provides a simplistic and easy to follow instructions on replacing a damaged or faulty DJI Mavic Mini propeller.
Make sure to have extra propellers. If you purchased a DJI Mavic Mini, it should have come with extra propellers.
Have extra screws only if needed, as some screws may be damaged.
You need a maximum of 8 propellers, as that is how many propellers are on the drone, although you only need the quantity that you are planning to replace.
Make sure the drone is compacted before starting the process, as this may help prevent accidentally breaking the drone arms.
필요한 것
After this guide, you’ll be able to replace your DJI Mavic Mini propellers easily.
