주요 콘텐츠로 건너뛰기
DJI Mavic Mini Propellers Replacement
필요한 것
  1. DJI Mavic Mini Propellers Replacement, Propellers: 1 단계, 이미지 1/3 DJI Mavic Mini Propellers Replacement, Propellers: 1 단계, 이미지 2/3 DJI Mavic Mini Propellers Replacement, Propellers: 1 단계, 이미지 3/3
    • Place the DJI Mavic Mini on a flat surface with the props oriented upwards.
    • For ease of access place the prop arms in the "open" position.
  2. DJI Mavic Mini Propellers Replacement: 2 단계, 이미지 1/3 DJI Mavic Mini Propellers Replacement: 2 단계, 이미지 2/3 DJI Mavic Mini Propellers Replacement: 2 단계, 이미지 3/3
    • Remove the 2.4 mm J000 screw from the damaged propeller.
    • When removing the screws, you may need to apply some pressure to the swivel mount that holds the propellers.
    • Remove the damaged propellers.
  3. DJI Mavic Mini Propellers Replacement: 3 단계, 이미지 1/2 DJI Mavic Mini Propellers Replacement: 3 단계, 이미지 2/2
    • Keep the 2.4 mm J000 screw from the damaged propeller to use again when fastening on the replacement.
    • While one or both propellers are removed for replacement, it is recommended that you inspect the exposed swivel mount for any debris which may impact drone performance.
    • Additionally, when fastening the replacement propeller make sure that the screw is inserted into the interior hole on the swivel mount.
결론
Chase Smith
회원 가입일: 02/22/22
147 평판
안내서 1개 작성함
Clemson, Team 1-2, Hunter Spring 2022 Clemson, Team 1-2, Hunter Spring 2022 회원
CLEM-HUNTER-S22S1G2
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 36
전체 시간: 899
