주요 콘텐츠로 건너뛰기
DJI Mavic Pro Propeller Replacement
필요한 것
  1. DJI Mavic Pro Propeller Replacement, Propellers: 1 단계, 이미지 1/3 DJI Mavic Pro Propeller Replacement, Propellers: 1 단계, 이미지 2/3 DJI Mavic Pro Propeller Replacement, Propellers: 1 단계, 이미지 3/3
    • Unfold your Dji Mavic Pro Drone.
  2. DJI Mavic Pro Propeller Replacement: 2 단계, 이미지 1/3 DJI Mavic Pro Propeller Replacement: 2 단계, 이미지 2/3 DJI Mavic Pro Propeller Replacement: 2 단계, 이미지 3/3
    • Push down slightly on the propeller you want to remove.
  3. DJI Mavic Pro Propeller Replacement: 3 단계, 이미지 1/3 DJI Mavic Pro Propeller Replacement: 3 단계, 이미지 2/3 DJI Mavic Pro Propeller Replacement: 3 단계, 이미지 3/3
    • There are 2 types of propellers on a DJI Mavic Pro drone: 1 with a white circle outline (shown in the image) and 1 without.
    • If the propeller you want to remove has a white outline like shown in the image, then turn the propeller counterclockwise to unlock its position.
  4. DJI Mavic Pro Propeller Replacement: 4 단계, 이미지 1/3 DJI Mavic Pro Propeller Replacement: 4 단계, 이미지 2/3 DJI Mavic Pro Propeller Replacement: 4 단계, 이미지 3/3
    • If the propeller you want to remove DOES NOT have a white outline, then turn the propeller clockwise to unlock its position.
  5. DJI Mavic Pro Propeller Replacement: 5 단계, 이미지 1/3 DJI Mavic Pro Propeller Replacement: 5 단계, 이미지 2/3 DJI Mavic Pro Propeller Replacement: 5 단계, 이미지 3/3
    • Pull up the propeller to remove it.
  6. DJI Mavic Pro Propeller Replacement: 6 단계, 이미지 1/3 DJI Mavic Pro Propeller Replacement: 6 단계, 이미지 2/3 DJI Mavic Pro Propeller Replacement: 6 단계, 이미지 3/3
    • To replace the propellers, check to match the propellers with the arm of the drone.
    • The propeller with a white circle will have to be placed on the arm of the drone with a white outline and the propeller without the white circle will be placed on the arm of the drone without the white outline.
  7. DJI Mavic Pro Propeller Replacement: 7 단계, 이미지 1/3 DJI Mavic Pro Propeller Replacement: 7 단계, 이미지 2/3 DJI Mavic Pro Propeller Replacement: 7 단계, 이미지 3/3
    • Align the parts outlined with red with the holes on the arm of the drone outlined by the red.
    • Push the propeller down.
  8. DJI Mavic Pro Propeller Replacement: 8 단계, 이미지 1/2 DJI Mavic Pro Propeller Replacement: 8 단계, 이미지 2/2
    • If the propeller has NO white mark (circle) then turn the propeller counterclockwise to lock its position.
    • If the propeller has a white mark (circle) then turn the propeller clockwise to lock its position.
  9. DJI Mavic Pro Propeller Replacement: 9 단계, 이미지 1/2 DJI Mavic Pro Propeller Replacement: 9 단계, 이미지 2/2
    • Check to see if the propeller is properly locked into place by slightly pulling it up.
    • If it is locked, then you can safely fly your drone.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Sophia Maxine Villarosa
회원 가입일: 01/12/22
196 평판
안내서 1개 작성함
York University, Team R-28, Melo-Thaiss Winter 2022 York University, Team R-28, Melo-Thaiss Winter 2022 회원
YORK-MELO-THAISS-W22SRG28
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 27
30일 전: 102
전체 시간: 4,227
