소개
This set of instructions will guide you through the replacements of the DJI Mavic Pro Upper Shell. You will need to remove the battery first in order to remove the upper shell. Before you begin, you should be aware that the plastic can end up slightly damaged when removing the shell.
부품
지정된 부품이 없습니다.
Grab both sides of the battery.
Pinch the releasing buttons on both sides of the battery.
Lift the battery up and out.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
Well done, good instructions - are the two screws under the tabs shorter than the others from the shell?
Awesome descriptions were perfect except for saying there is 4 acres to be removed under the tabs behind the gimbal. Theirs only 2
