주요 콘텐츠로 건너뛰기
DJI Mini 3 Pro Gimbal Replacement
필요한 것
동영상 지침
결론
To reassemble your device, follow these instructions.
다른 5명이 해당 안내서를 완성하였습니다.
Arty
회원 가입일: 10/27/19
24,406 평판
안내서 92개 작성하였습니다
댓글 9개
Does anyone have a source for replacing the little rubber gimbal mounts?
Andre Purdy - 답글
HI there! Does anyone know where I can buy the whole gimbal in USA? I remember seeing it somewhere but cannot find it
gbonilla - 답글
Go to YouTube and check the link to the gimbal assembly in the description below the video
Arty -
mini 3 pro com port not show on device manegar any help.
Limon Khan - 답글
Start trembling during flight after a horizontal stop. At the start, I can hear the gimbal noise from trembling (before taking off). I gently touch it, and it stops. I take off and fly a long distance.
If I stop it or it stops it by signal loss, the trembling starts again. if I never stop it and take gentle curves back, it may work. At abrupt stops, it starts trembling. I bring the drone back to me at 1-meter height. I gently touch the gimbal (without landing), and it stops. Then I fly again (if the battery is low, I land, change the battery, and start again, same steps, every time). I will probably buy a new one, so I can send this to repairs - did not check the guarantee yet.
- no problems during climbing up.
- only on horizontal movements and hard stops (release the lever on the controller).
I will try never to release the lever abruptly and never lose signal (a signal lost could be a hard brake, also)
??? Calibration can stop this strange error ????
Dorin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 28
7일 전: 202
30일 전: 733
전체 시간: 19,356
