이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
Determine if the propellor is clockwise or counter-clockwise rotating.
If this icon is missing or you can't read it, you can determine the direction of rotation by examining the propellor.
Loosen a clockwise rotating propeller by holding the motor with one hand and spinning the propellor clockwise.
Remove the propellor.
Loosen a counter-clockwise rotating propeller by holding the motor with one hand and spinning the propellor counter-clockwise.
Remove the following screws from the underside of the Phantom:
Twelve 2.0 mm hex bolts
Four Phillips #00 screws
The GPS cable molex connector is located on the backside of the mainboard, near the battery opening.
Pull the GPS connector straight up out of its socket.
Lift the top shell case up and remove it from the body of the Phantom.
다른 4명이 해당 안내서를 완성하였습니다.
