주요 콘텐츠로 건너뛰기
DJI Phantom 2 Vision+ Propellers Removal
필요한 것
  1. DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: 1 단계, 이미지 3개 중 1개 DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: 1 단계, 이미지 3개 중 2개 DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: 1 단계, 이미지 3개 중 3개
    • Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
    • The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
  2. DJI Phantom 2 Vision+ Propellers Removal, Propellers: 2 단계, 이미지 1개 중 1개
    • Determine if the propellor is clockwise or counter-clockwise rotating.
    • Each arm is labeled with a rotation icon that shows the direction of propellor rotation.
    • If this icon is missing or you can't read it, you can determine the direction of rotation by examining the propellor.
    • A clockwise rotating propellor pushes air down while rotating clockwise, and the opposite is true for a counter-clockwise rotating propellor, and the propellor blade slopes up in the direction of rotation.
  3. DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: 3 단계, 이미지 3개 중 1개 DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: 3 단계, 이미지 3개 중 2개 DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: 3 단계, 이미지 3개 중 3개
    • Loosen a clockwise rotating propeller by holding the motor with one hand and spinning the propellor clockwise.
    • Remove the propellor.
  4. DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: 4 단계, 이미지 3개 중 1개 DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: 4 단계, 이미지 3개 중 2개 DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: 4 단계, 이미지 3개 중 3개
    • Loosen a counter-clockwise rotating propeller by holding the motor with one hand and spinning the propellor counter-clockwise.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
David Hoyt
회원 가입일: 04/09/10
4,053 평판
안내서 41개를 작성함
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010 회원
CPSU-AMIDO-S10S25G89
4 회원들
안내서 61개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 15
전체 시간: 7,304
