주요 콘텐츠로 건너뛰기
DJI Phantom 2 Vision Plus GPS Signal Improvement Technique
필요한 것
동영상 개요
  1. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Case Top Shell: 1 단계, 이미지 2개 중 1개 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Case Top Shell: 1 단계, 이미지 2개 중 2개
    • Remove the following screws from the underside of the Phantom:
    • Twelve 2.0 mm hex bolts
    • Four Phillips #00 screws
  2. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique: 2 단계, 이미지 2개 중 1개 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique: 2 단계, 이미지 2개 중 2개
    • Gently lift up the top shell case.
    • Do not attempt to fully remove the top shell. The GPS cable is still attached to the mainboard, avoid lifting the case too high or you may damage this connection.
  3. DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Unplug GPS connector and remove case: 3 단계, 이미지 3개 중 1개 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Unplug GPS connector and remove case: 3 단계, 이미지 3개 중 2개 DJI Phantom 2 Vision Plus GPS Signal Improvement Technique, Unplug GPS connector and remove case: 3 단계, 이미지 3개 중 3개
    • The GPS cable molex connector is located on the backside of the mainboard, near the battery opening.
    • Pull the GPS connector straight up out of its socket.
    • Lift the top shell case up and remove it from the body of the Phantom.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
474,978 평판
안내서 538개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,649개를 작성함
3가이드 댓글
hello do you still help with phantom drones
George Aguirre - 답글
do you still help with drones/
George Aguirre - 답글
Isn't it better to connect the aluminium foil to the GPS GND for better isolation?
Bruno Duarte - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 14
전체 시간: 4,783
