이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will illustrate the needed steps in removing the plastic shell from the DJI Phantom 3 Advanced. This includes the removal of screws that secure the two halves of the shell together. This guide also informs how to safely remove the top shell after it is unscrewed. This is a process required for removing several other components.
필요한 것
With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
Slowly remove the upper half of the plastic case about halfway. There is a ribbon cable that's connects the cover and the control board.
Follow the ribbon cable to the control board and locate the connector that connects the cable to the control board.
Press the tab on the side of the connector and pull up on the cable.
Continue to remove the shell the rest of the way.
다른 10명이 해당 안내서를 완성하였습니다.
댓글 3개
Great Job Robert! Even the “Phantom Pilots Forum” had no recent recommendations for a disassembly manual, as DJI likes to “Fixit” themselves!
