주요 콘텐츠로 건너뛰기
DJI Phantom 3 Advanced Landing Gear Replacement
필요한 것
  1. DJI Phantom 3 Advanced Landing Gear Replacement, Battery: 1 단계, 이미지 1/2 DJI Phantom 3 Advanced Landing Gear Replacement, Battery: 1 단계, 이미지 2/2
    • With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
    • Remember to disarm and power down your quadcopter before beginning any disassembly.
  2. DJI Phantom 3 Advanced Landing Gear Replacement: 2 단계, 이미지 1/2 DJI Phantom 3 Advanced Landing Gear Replacement: 2 단계, 이미지 2/2
    • Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
    • With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
  3. DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: 3 단계, 이미지 1/3 DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: 3 단계, 이미지 2/3 DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: 3 단계, 이미지 3/3
    • Turn the phantom upside down.
    • Remove the eight 7.5mm long 3mm screws, securing the landing gear to the body of the quadcopter, with a T-8 screwdriver.
  4. DJI Phantom 3 Advanced Landing Gear Replacement: 4 단계, 이미지 1/3 DJI Phantom 3 Advanced Landing Gear Replacement: 4 단계, 이미지 2/3 DJI Phantom 3 Advanced Landing Gear Replacement: 4 단계, 이미지 3/3
    • Remove the rubber spacer in the landing gear by pushing the spacer out of the slot with your finger.
  5. DJI Phantom 3 Advanced Landing Gear Replacement: 5 단계, 이미지 1/3 DJI Phantom 3 Advanced Landing Gear Replacement: 5 단계, 이미지 2/3 DJI Phantom 3 Advanced Landing Gear Replacement: 5 단계, 이미지 3/3
    • Using a plastic opening tool, carefully separate the two pieces of plastic of the landing gear.
    • Be careful not to break the wire attached, as this is your receiver antenna.
  6. DJI Phantom 3 Advanced Landing Gear Replacement: 6 단계, 이미지 1/3 DJI Phantom 3 Advanced Landing Gear Replacement: 6 단계, 이미지 2/3 DJI Phantom 3 Advanced Landing Gear Replacement: 6 단계, 이미지 3/3
    • Feed the wire and attached plastic through the hole in the landing gear.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Quinn Tirpak
회원 가입일: 10/06/16
319 평판
안내서 2개 작성하였습니다
Cal Poly, Team 10-2, Livingston Fall 2016 Cal Poly, Team 10-2, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S10G2
3 회원들
안내서 12개 작성하였습니다
댓글 한 개
I have a single coax cable in my landing gear. the gear broke and the wire tore off the connector. How do I fix this?
Art - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 21
전체 시간: 3,813
