주요 콘텐츠로 건너뛰기
DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement
필요한 것
  1. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: 2 단계, 이미지 2개 중 1개 DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: 2 단계, 이미지 2개 중 2개
    • Remove three screws using a Phillips #00 screwdriver.
  3. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: 3 단계, 이미지 2개 중 1개 DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: 4 단계, 이미지 2개 중 1개 DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: 4 단계, 이미지 2개 중 2개
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: 5 단계, 이미지 2개 중 1개 DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: 5 단계, 이미지 2개 중 2개
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
  6. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement, Back Con Board: 6 단계, 이미지 1개 중 1개
    • Remove the three PH0 screws securing the PCB to the remote.
  7. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: 7 단계, 이미지 2개 중 1개 DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: 7 단계, 이미지 2개 중 2개
    • Remove each of the three ribbon cables from their tabs by pulling in a horizontal direction away from the socket.
    • Remove the Back Con Board.
  8. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: 8 단계, 이미지 1개 중 1개
    • The board can now be replaced.
결론
작성자
6다른 기여자 명과 함께
Gunnar Behny
회원 가입일: 10/02/18
154 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 11
전체 시간: 1,171
