주요 콘텐츠로 건너뛰기
DJI Phantom 4 Advanced Remote Controller Battery Replacement
필요한 것
  1. DJI Phantom 4 Advanced Remote Controller Battery Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. DJI Phantom 4 Advanced Remote Controller Battery Replacement: 2 단계, 이미지 2개 중 1개 DJI Phantom 4 Advanced Remote Controller Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Remove three screws using a Phillips #00 screwdriver.
  3. DJI Phantom 4 Advanced Remote Controller Battery Replacement: 3 단계, 이미지 2개 중 1개 DJI Phantom 4 Advanced Remote Controller Battery Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. DJI Phantom 4 Advanced Remote Controller Battery Replacement: 4 단계, 이미지 2개 중 1개 DJI Phantom 4 Advanced Remote Controller Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. DJI Phantom 4 Advanced Remote Controller Battery Replacement: 5 단계, 이미지 2개 중 1개 DJI Phantom 4 Advanced Remote Controller Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
  6. DJI Phantom 4 Advanced Remote Controller Battery Replacement, Battery: 6 단계, 이미지 1개 중 1개
    • The battery is attached to the back plastic, and is towards the bottom of the remote.
    • Unplug the cord that is connected to the bottom of the main board.
  7. DJI Phantom 4 Advanced Remote Controller Battery Replacement: 7 단계, 이미지 1개 중 1개
    • After the cord is unplugged, remove the battery by lifting upon the plastic cover, which the battery is attached to.
  8. DJI Phantom 4 Advanced Remote Controller Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Once the cover is off you can access the battery.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
cade knott
회원 가입일: 10/02/18
511 평판
안내서 3개를 작성함
4가이드 댓글
Wo kann ich den Akku bestellen? Danke für die Hilfe!
Xl S - 답글
does someone know where to buy the akku?
Xl S - 답글
Ich habe ein Erzatz Akku eingesetzt mit den gleichen Strom Werten, beim aufladen stelle ich fest das der Akku nicht ladet..
Es blinkt bloß ( schnell) auf einer LED.
Wo kann die Ursache liegen.
Matthias Meier - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 95
전체 시간: 14,703
