주요 콘텐츠로 건너뛰기
DJI Phantom 4 Advanced Remote Controller Power Button Replacement
필요한 것
  1. DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 2 단계, 이미지 2개 중 1개 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 2 단계, 이미지 2개 중 2개
    • Remove three screws using a Phillips #00 screwdriver.
  3. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 3 단계, 이미지 2개 중 1개 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 4 단계, 이미지 2개 중 1개 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 4 단계, 이미지 2개 중 2개
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 5 단계, 이미지 2개 중 1개 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 5 단계, 이미지 2개 중 2개
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
  6. DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Motherboard: 6 단계, 이미지 3개 중 1개 DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Motherboard: 6 단계, 이미지 3개 중 2개 DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Motherboard: 6 단계, 이미지 3개 중 3개
    • Disconnect ribbon tabs 1,2,5,8G, and 3.
    • Remove ribbon tab by pulling gently along motherboard. Do not pull straight out.
    • Then remove the plugs
  7. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 7 단계, 이미지 2개 중 1개 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 7 단계, 이미지 2개 중 2개
    • With the Phillips #00 screwdriver, remove the two Phillips screws.
  8. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 8 단계, 이미지 1개 중 1개
    • Double check to make sure all tabs, plugs and screws are removed or disconnected.
    • Gently lift motherboard out of the case.
  9. DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Power Button: 9 단계, 이미지 2개 중 1개 DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Power Button: 9 단계, 이미지 2개 중 2개
    • Carefully remove the plastic. This will help you gain access to the power button panel.
  10. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 10 단계, 이미지 2개 중 1개 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 10 단계, 이미지 2개 중 2개
    • With a Phillips #00 screwdriver, remove the two screws on the power button panel.
  11. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 11 단계, 이미지 1개 중 1개
    • Gently pull the power button out from the panel. Replace it with a new one.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Angel Cortez
회원 가입일: 10/02/18
246 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 10
전체 시간: 1,029
