주요 콘텐츠로 건너뛰기
  1. Use your finger tips to pinch the damaged propeller. Twist the propeller counterclockwise and pull up to remove.
    • Use your finger tips to pinch the damaged propeller.
    • Twist the propeller counterclockwise and pull up to remove.
  2. Remove the eight 7 mm hex screws by turning counterclockwise with a 2 mm hex bit. Remove the eight 7 mm hex screws by turning counterclockwise with a 2 mm hex bit.
    • Remove the eight 7 mm hex screws by turning counterclockwise with a 2 mm hex bit.
  3. Pry the LED motor covers off with a metal spudger.
    • Pry the LED motor covers off with a metal spudger.
    • The prying location is marked by an indent that points outward from the arm.
  4. Pry the paper covering off the four corners with a metal spudger.
    • Pry the paper covering off the four corners with a metal spudger.
  5. Apple Watch Kits
    Screen and battery repairs just got easier.
    지금 장보기
    Apple Watch Kits
    지금 장보기
  6. Remove the twelve 8.7 mm hex screws with a 2 mm hex bit from the motor bases.
    • Remove the twelve 8.7 mm hex screws with a 2 mm hex bit from the motor bases.
  7. Flip the drone on its back Remove the eight 4.5 mm hex screws by turning them counterclockwise with a 1.5 mm hex bit.
    • Flip the drone on its back
    • Remove the eight 4.5 mm hex screws by turning them counterclockwise with a 1.5 mm hex bit.
    • Separate the mesh from the drone by pulling up gently and rocking left to right.
    • The cable connects from the camera to the drone. Pulling up could rip the connection. Tilt the mesh 90 degrees towards the cable.
  8. Remove two 1.2mm screws using the JIS #000 bit from the camera cable retaining bracket.
    • Remove two 1.2mm screws using the JIS #000 bit from the camera cable retaining bracket.
  9. Lift the camera connector at one end with your hand and remove the mesh.
    • Lift the camera connector at one end with your hand and remove the mesh.
  10. Remove the two 1.2 mm screws using a JIS #000 bit from the antenna retaining bracket. Pull the four U.FL antennae up. The U.FL antenna connectors are fragile.
    • Remove the two 1.2 mm screws using a JIS #000 bit from the antenna retaining bracket.
    • Pull the four U.FL antennae up.
    • The U.FL antenna connectors are fragile.
    • Remove the two 4 mm screws using a JIS #000 bit.
  11. Pry apart the clamshell at the motor end. Separate the clamshell.
    • Pry apart the clamshell at the motor end.
    • Separate the clamshell.
    • Two wires connect from the lower frame to the upper frame at the front of the drone. Pulling the clamshell apart hard may damage the connectors and wires.
  12. Press the connector tabs with a spudger and pull on the wire simultaneously.
    • Press the connector tabs with a spudger and pull on the wire simultaneously.
    • Remove the shell from the rest of the drone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
David Hudson
회원 가입일: 2018년 10월 08일
301 평판
안내서 2개 작성하였습니다
Cal Poly, Team S15-G6, White Fall 2018 Cal Poly, Team S15-G6, White Fall 2018 회원
CPSU-WHITE-F18S15G6
4 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 33
