주요 콘텐츠로 건너뛰기
DJI Phantom H3-2D GoPro Camera Installation
필요한 것
  1. DJI Phantom H3-2D GoPro Camera Installation, Open the Battery Compartment: 1 단계, 이미지 3개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Open the Battery Compartment: 1 단계, 이미지 3개 중 2개 DJI Phantom H3-2D GoPro Camera Installation, Open the Battery Compartment: 1 단계, 이미지 3개 중 3개
    • Press down on battery door release tab to flip the battery door open.
  2. DJI Phantom H3-2D GoPro Camera Installation, Remove the Battery: 2 단계, 이미지 3개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Remove the Battery: 2 단계, 이미지 3개 중 2개 DJI Phantom H3-2D GoPro Camera Installation, Remove the Battery: 2 단계, 이미지 3개 중 3개
    • Pull out the battery pack.
    • Avoid pulling on the battery wires, excess stress may break the wires, damage the power connectors, or crack the internal solder joints.
  3. DJI Phantom H3-2D GoPro Camera Installation, Disconnect the Battery: 3 단계, 이미지 2개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Disconnect the Battery: 3 단계, 이미지 2개 중 2개
    • Pull the two halves of the XT60 power connector apart.
    • It's a tight fit, so be careful not to hit your drone or yank on the cables when it releases!
  4. DJI Phantom H3-2D GoPro Camera Installation, Identifying Silver and Black Collets: 4 단계, 이미지 2개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Identifying Silver and Black Collets: 4 단계, 이미지 2개 중 2개
    • Silver-topped propeller collets unscrew counter-clockwise
    • Black-topped propeller collets unscrew clockwise
  5. DJI Phantom H3-2D GoPro Camera Installation, Unscrewing Silver Collets: 5 단계, 이미지 3개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Unscrewing Silver Collets: 5 단계, 이미지 3개 중 2개 DJI Phantom H3-2D GoPro Camera Installation, Unscrewing Silver Collets: 5 단계, 이미지 3개 중 3개
    • For propellors with silver collets: Use a 12 mm wrench or socket to loosen silver collets in the counter-clockwise direction.
    • Once free, unscrew and remove the collet.
  6. DJI Phantom H3-2D GoPro Camera Installation, Unscrewing Black Collets: 6 단계, 이미지 3개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Unscrewing Black Collets: 6 단계, 이미지 3개 중 2개 DJI Phantom H3-2D GoPro Camera Installation, Unscrewing Black Collets: 6 단계, 이미지 3개 중 3개
    • For propellors with black collets: Use a 12 mm wrench or socket to loosen black collets in the clockwise direction.
  7. DJI Phantom H3-2D GoPro Camera Installation, Remove the Propeller: 7 단계, 이미지 3개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Remove the Propeller: 7 단계, 이미지 3개 중 2개 DJI Phantom H3-2D GoPro Camera Installation, Remove the Propeller: 7 단계, 이미지 3개 중 3개
    • Gently press down the motor shaft and lift the propeller up to remove it.
  8. DJI Phantom H3-2D GoPro Camera Installation, Remove Case Screws: 8 단계, 이미지 3개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Remove Case Screws: 8 단계, 이미지 3개 중 2개 DJI Phantom H3-2D GoPro Camera Installation, Remove Case Screws: 8 단계, 이미지 3개 중 3개
    • After removing all four propellors, flip the drone over.
    • Remove the following screws from the underside of the drone:
    • Twelve 2.0 mm hex screws
    • Four Phillips #0 screws
  9. DJI Phantom H3-2D GoPro Camera Installation, Unplug Magnetometer: 9 단계, 이미지 3개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Unplug Magnetometer: 9 단계, 이미지 3개 중 2개 DJI Phantom H3-2D GoPro Camera Installation, Unplug Magnetometer: 9 단계, 이미지 3개 중 3개
    • Loosen the cable from the plastic landing gear.
    • Unplug the magnetometer molex connector.
  10. DJI Phantom H3-2D GoPro Camera Installation, Remove the Top Shell: 10 단계, 이미지 3개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Remove the Top Shell: 10 단계, 이미지 3개 중 2개 DJI Phantom H3-2D GoPro Camera Installation, Remove the Top Shell: 10 단계, 이미지 3개 중 3개
    • Lift up on the top portion of the shell and set it on its side.
    • Do not attempt to fully remove the case. The GPS and Magnetometer cables connect the top shell to the rest of the Phantom, be careful not to stress or break these cables.
  11. DJI Phantom H3-2D GoPro Camera Installation, Disconnect GPS Cable: 11 단계, 이미지 2개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Disconnect GPS Cable: 11 단계, 이미지 2개 중 2개
    • Lift the GPS cable molex connector up out of its socket on the main board.
  12. DJI Phantom H3-2D GoPro Camera Installation, Loosen Magnetometer Cable: 12 단계, 이미지 3개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Loosen Magnetometer Cable: 12 단계, 이미지 3개 중 2개 DJI Phantom H3-2D GoPro Camera Installation, Loosen Magnetometer Cable: 12 단계, 이미지 3개 중 3개
    • Gently pull the slack of the magnetometer cable through the case bottom shell.
    • The case top shell should now have enough slack to work on the interior of the Phantom.
  13. DJI Phantom H3-2D GoPro Camera Installation, Prepare G8 Connector Cable: 13 단계, 이미지 3개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Prepare G8 Connector Cable: 13 단계, 이미지 3개 중 2개 DJI Phantom H3-2D GoPro Camera Installation, Prepare G8 Connector Cable: 13 단계, 이미지 3개 중 3개
    • Twist the molex and cable as shown to prepare it for insertion through the case bottom shell.
  14. DJI Phantom H3-2D GoPro Camera Installation, Pass the G8 connector through the case: 14 단계, 이미지 3개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Pass the G8 connector through the case: 14 단계, 이미지 3개 중 2개 DJI Phantom H3-2D GoPro Camera Installation, Pass the G8 connector through the case: 14 단계, 이미지 3개 중 3개
    • Insert the molex connector through one of the landing gear holes and case bottom shell.
    • Pull the cable through.
    • This is a really tight fit, take your time and avoid damaging the molex connector or cable. We found that gently rocking the molex connector back and forth through the hole eventually wiggled it through.
  15. DJI Phantom H3-2D GoPro Camera Installation, Install the mounting bracket: 15 단계, 이미지 3개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Install the mounting bracket: 15 단계, 이미지 3개 중 2개 DJI Phantom H3-2D GoPro Camera Installation, Install the mounting bracket: 15 단계, 이미지 3개 중 3개
    • Place the H3-2D mounting bracket on the bottom side of the Phantom.
    • Line up the mounting holes and screw in the two bolts to secure the mounting bracket.
  16. DJI Phantom H3-2D GoPro Camera Installation, Prepare the other side of the G8 cable: 16 단계, 이미지 2개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Prepare the other side of the G8 cable: 16 단계, 이미지 2개 중 2개
    • Twist the other end of the G8 cable molex connector as shown in order to plug in the H3-2D gimbal.
  17. DJI Phantom H3-2D GoPro Camera Installation, Plugging in the H3-2D gimbal: 17 단계, 이미지 3개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Plugging in the H3-2D gimbal: 17 단계, 이미지 3개 중 2개 DJI Phantom H3-2D GoPro Camera Installation, Plugging in the H3-2D gimbal: 17 단계, 이미지 3개 중 3개
    • Pass the G8 molex connector through the side of the H3-2D gimbal.
    • Plug in and firmly secure the connector.
  18. DJI Phantom H3-2D GoPro Camera Installation, Plug in the G8 connector: 18 단계, 이미지 3개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Plug in the G8 connector: 18 단계, 이미지 3개 중 2개 DJI Phantom H3-2D GoPro Camera Installation, Plug in the G8 connector: 18 단계, 이미지 3개 중 3개
    • Pull the gimbal wire through the case bottom shell and plug in the connector to the G8 plug on the mainboard.
  19. DJI Phantom H3-2D GoPro Camera Installation, Prepare the Gimbal for installation: 19 단계, 이미지 2개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Prepare the Gimbal for installation: 19 단계, 이미지 2개 중 2개
    • Place the gimbal on the mount with the front facing the same side as the battery cover.
  20. DJI Phantom H3-2D GoPro Camera Installation, Mounting the Gimbal: 20 단계, 이미지 3개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Mounting the Gimbal: 20 단계, 이미지 3개 중 2개 DJI Phantom H3-2D GoPro Camera Installation, Mounting the Gimbal: 20 단계, 이미지 3개 중 3개
    • Mount the four rubber dampers on the gimbal to the mounting bracket.
    • Pinch two sides of the rubber dampers and press it into the mounting bracket holes.
  21. DJI Phantom H3-2D GoPro Camera Installation, Ensure the dampers are installed securely: 21 단계, 이미지 2개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Ensure the dampers are installed securely: 21 단계, 이미지 2개 중 2개
    • Confirm the dampers are installed correctly by twisting them at least 180 degrees.
    • If a damper unmounts, it was not installed correctly. Repeat the previous step for any unmounted dampers.
  22. DJI Phantom H3-2D GoPro Camera Installation, Clean up the gimbal cable: 22 단계, 이미지 2개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Clean up the gimbal cable: 22 단계, 이미지 2개 중 2개
    • Pull the excess slack in the gimbal cable up into the body of the Phantom.
    • When reinstalling the case top shell, be careful not to pinch any wires.
  23. DJI Phantom H3-2D GoPro Camera Installation, Install GoPro: 23 단계, 이미지 3개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Install GoPro: 23 단계, 이미지 3개 중 2개 DJI Phantom H3-2D GoPro Camera Installation, Install GoPro: 23 단계, 이미지 3개 중 3개
    • Line up the GoPro camera with the pins on the gimbal mount.
    • Press the GoPro camera firmly against the gimbal and ensure a snug fit.
  24. DJI Phantom H3-2D GoPro Camera Installation, Install the securing bracket: 24 단계, 이미지 3개 중 1개 DJI Phantom H3-2D GoPro Camera Installation, Install the securing bracket: 24 단계, 이미지 3개 중 2개 DJI Phantom H3-2D GoPro Camera Installation, Install the securing bracket: 24 단계, 이미지 3개 중 3개
    • Place the securing bracket over the camera and line up the bolt holes.
    • Secure the two mounting screws with a Phillips #0 driver.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
David Hoyt
회원 가입일: 04/09/10
4,053 평판
안내서 41개를 작성함
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010 회원
CPSU-AMIDO-S10S25G89
4 회원들
안내서 61개를 작성함
1가이드 댓글
were can i get a g8 wire connector
123jlanza - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 19
전체 시간: 2,414
