주요 콘텐츠로 건너뛰기
DJI Spark Lid Replacement
필요한 것
  1. DJI Spark Lid Replacement, Propellers: 1 단계, 이미지 1/1
    • Push down on the propeller that is being replaced.
  2. DJI Spark Lid Replacement: 2 단계, 이미지 1/2 DJI Spark Lid Replacement: 2 단계, 이미지 2/2
    • Twist the propeller until it feels loose.
    • Pull on it until it comes off.
  3. DJI Spark Lid Replacement, Battery: 3 단계, 이미지 1/3 DJI Spark Lid Replacement, Battery: 3 단계, 이미지 2/3 DJI Spark Lid Replacement, Battery: 3 단계, 이미지 3/3
    • Flip the drone over.
    • Grip the left and right sides of the battery.
    • Slide firmly forward until it pops out.
  4. DJI Spark Lid Replacement, Lid: 4 단계, 이미지 1/3 DJI Spark Lid Replacement, Lid: 4 단계, 이미지 2/3 DJI Spark Lid Replacement, Lid: 4 단계, 이미지 3/3
    • Remove the four 1.5mm Hex screws.
    • Remove the two 1.5mm Hex screws near the camera head.
    • You may need to remove plastic nubs from the hex screws using a spudger first.
  5. DJI Spark Lid Replacement: 5 단계, 이미지 1/3 DJI Spark Lid Replacement: 5 단계, 이미지 2/3 DJI Spark Lid Replacement: 5 단계, 이미지 3/3
    • Hold the drone so the lid is facing up.
    • Insert the plastic opening tool into the side of the drone.
    • Slide the tool around the perimeter until you can lift the top off.
결론
Uzochi Anyanwu
회원 가입일: 10/21/19
408 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S1-G7, Botvin Fall 2019 UMass Dartmouth, Team S1-G7, Botvin Fall 2019 회원
UMASSD-BOTVIN-F19S1G7
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 11
전체 시간: 969
