주요 콘텐츠로 건너뛰기
DKnight MagicBox II Button Panel Replacement
필요한 것
  1. DKnight MagicBox II Button Panel Replacement, Front Panel Assembly: 1 단계, 이미지 1/2 DKnight MagicBox II Button Panel Replacement, Front Panel Assembly: 1 단계, 이미지 2/2
    • Using Blue Plastic opening tool pry the top rubber cover, then using the same tool remove the bottom panel
  2. DKnight MagicBox II Button Panel Replacement: 2 단계, 이미지 1/3 DKnight MagicBox II Button Panel Replacement: 2 단계, 이미지 2/3 DKnight MagicBox II Button Panel Replacement: 2 단계, 이미지 3/3
    • There are four prongs on the grill in the corners, closest to the power button switch. Use the plastic opening tool to release all four prongs from the panel, and then slide the plastic opening tool along the edge of the grill to allow it to easily slide off.
  3. DKnight MagicBox II Button Panel Replacement: 3 단계, 이미지 1/2 DKnight MagicBox II Button Panel Replacement: 3 단계, 이미지 2/2
    • On the back panel (Opposite to the side containing the two speakers), Use the Philips head PH1 to remove all 7 screws (Screws: Head PH1 , Length 7cm).
  4. DKnight MagicBox II Button Panel Replacement: 4 단계, 이미지 1/2 DKnight MagicBox II Button Panel Replacement: 4 단계, 이미지 2/2
    • Pull apart the two faces to separate the back panel from the front face plate.
  5. DKnight MagicBox II Button Panel Replacement, Motherboard: 5 단계, 이미지 1/2 DKnight MagicBox II Button Panel Replacement, Motherboard: 5 단계, 이미지 2/2
    • Remove the single screw holding the motherboard to the front panel (Screw : Head PH1, Size .5 cm)
  6. DKnight MagicBox II Button Panel Replacement: 6 단계, 이미지 1/1
    • Using your fingers gently pry the motherboard loose from the black insulant adhesive
  7. DKnight MagicBox II Button Panel Replacement: 7 단계, 이미지 1/1
    • Disconnect the Button Panel plug (Largest of the Plugs, it can be traced back to the button panel easily)
  8. DKnight MagicBox II Button Panel Replacement: 8 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to push down on the safety prongs on the plastic switch. Then Disconnect the Power Wire plug by hand (Red medium),
  9. DKnight MagicBox II Button Panel Replacement: 9 단계, 이미지 1/1
    • Use the tweezers to push down on the two safety prongs on the plastic switch. Then Disconnect the two Speaker plug connections by hand (Two Smaller Plugs)
  10. DKnight MagicBox II Button Panel Replacement: 10 단계, 이미지 1/2 DKnight MagicBox II Button Panel Replacement: 10 단계, 이미지 2/2
    • The Motherboard is now free from the speaker assembly
  11. DKnight MagicBox II Button Panel Replacement, Button Panel: 11 단계, 이미지 1/1
    • Remove the three screws holding the button board in place (Screw Head PH1, Size 0.5 cm)
    • You should now be able to remove the button panel from the device.
결론
Anthony
회원 가입일: 02/04/16
695 평판
안내서 3개 작성하였습니다
USF Tampa, Team 17-1, Blackwell Winter 2016 USF Tampa, Team 17-1, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S17G1
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 922
