주요 콘텐츠로 건너뛰기
DOSS SoundBox Base-plate Removal Replacement
필요한 것
  1. DOSS SoundBox Base-plate Removal Replacement, Base-plate Removal: 1 단계, 이미지 1/3 DOSS SoundBox Base-plate Removal Replacement, Base-plate Removal: 1 단계, 이미지 2/3 DOSS SoundBox Base-plate Removal Replacement, Base-plate Removal: 1 단계, 이미지 3/3
    • Locate the four 3/32" screws on the bottom of your device.
    • Using a JIS #00 screwdriver, remove the four 3/32" screws.
    • After removing the screws, lift the cover off of the device.
  2. DOSS SoundBox Base-plate Removal Replacement: 2 단계, 이미지 1/1
    • Using a JIS #1 screwdriver, remove the six 3/32" screws that attach the base-plate to the speaker enclosure. These screws are marked with red circles.
    • Using a JIS #000 screwdriver, remove the two 1/16" screws from the areas marked with an orange circle.
    • Having the magnetic pad handy will be beneficial, as these screws are very small and easily lost.
  3. DOSS SoundBox Base-plate Removal Replacement: 3 단계, 이미지 1/1
    • Lift the base-plate off of the enclosure.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Brendan Harkreader
회원 가입일: 09/27/18
517 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 33
전체 시간: 1,972
