주요 콘텐츠로 건너뛰기
DOSS SoundBox Speaker Replacement
필요한 것
  1. DOSS SoundBox Speaker Replacement, Speaker: 1 단계, 이미지 2개 중 1개 DOSS SoundBox Speaker Replacement, Speaker: 1 단계, 이미지 2개 중 2개
    • Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body.
    • Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
    • The smaller screws are still the same length, but they have smaller screw heads. You can use the same screwdriver for both.
    • Using a Magnetic Mat throughout this process will help prevent losing screws.
  2. DOSS SoundBox Speaker Replacement: 2 단계, 이미지 2개 중 1개 DOSS SoundBox Speaker Replacement: 2 단계, 이미지 2개 중 2개
    • Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires.
  3. DOSS SoundBox Speaker Replacement: 3 단계, 이미지 2개 중 1개 DOSS SoundBox Speaker Replacement: 3 단계, 이미지 2개 중 2개
    • Use a soldering iron to de-solder the two speaker wires from the speaker itself.
    • The speakers are ready to be removed and replaced.
    • Ensure that the device is turned off when handling bare wire.
    • Soldering iron is very hot.
결론
To reassemble your device, follow instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Brendan Harkreader
회원 가입일: 09/27/18
543 평판
안내서 3개를 작성함
1가이드 댓글
The instructions say: "The speakers are ready to be removed and replaced." But nowhere in this article am I told where to get replacement speakers. Am I just on my own for that? This website has always been so helpful in providing links for such things. :(
Janie Thurman - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 56
전체 시간: 3,270
