주요 콘텐츠로 건너뛰기
DWFP55130 Regulator spring Replacement
필요한 것
  1. DWFP55130 Regulator spring Replacement, Remove regulator knob: 1 단계, 이미지 1개 중 1개
    • Unscrew and remove the black plastic regulator knob. While unscrewing, it will reach a stop and will keep like cannot unscrew further. Just break through the stop and unscrew to completely remove
  2. DWFP55130 Regulator spring Replacement, Remove plunger actuator: 2 단계, 이미지 1개 중 1개
    • Use needle nose pliers to remove the plunger.
  3. DWFP55130 Regulator spring Replacement, Use Philips #3 (large) screw driver: 3 단계, 이미지 1개 중 1개
    • Very gently unscrew the valve with a Philips #3 screwdriver. Take care not to destroy the plastic part
  4. DWFP55130 Regulator spring Replacement, Remove plastic valve: 4 단계, 이미지 1개 중 1개
    • Use needle nose pliers to pull plastic valve assembly out
  5. DWFP55130 Regulator spring Replacement, Replace broken screw: 5 단계, 이미지 1개 중 1개
    • Replace screw if broken. Photo is not of the original spring. The original spring had corroded and broken into 50 pieces. The spring doesn’t have to be a perfect fit, just has to hold the part in place. The original spring was approx 6mm wide, 20mm tall and 0.5mm thickness wire.
  6. DWFP55130 Regulator spring Replacement, Reassemble: 6 단계, 이미지 1개 중 1개
    • Carry out steps in reverse to reassemble compressor and you’re done
결론
작성자
2다른 기여자 명과 함께
Imran Latif
회원 가입일: 02/08/23
158 평판
안내서 1개를 작성함
5가이드 댓글
do you know the replacement part numbers just in case?
myke - 답글
The replacement parts are not listed in the manual and not available for sale. Hence this workaround.
Imran Latif - 답글
what type of spring did you replace it with?
Gaeilge 6 - 답글
Random screw I found from a 3D printer part. Size and shape were both different than the original spring. As long as the dimension are similar to 6mm wide and 20mm tall, it would work. The spring I used was not 6mm by 2omm but close enough that it worked.
Imran Latif - 답글
Replaced and still leaks. Tried replacing o ring and still leaks.
Rollin Blanton - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 20
지난 30일: 69
전체 시간: 1,396
