주요 콘텐츠로 건너뛰기
DYMO LabelManager 160 Keyboard Replacement
필요한 것
  1. DYMO LabelManager 160 Keyboard Replacement, Batteries: 1 단계, 이미지 1/1
    • Place the device face-down to access the battery compartment.
  2. DYMO LabelManager 160 Keyboard Replacement: 2 단계, 이미지 1/1
    • Remove the compartment cover to reveal the batteries. Remove the 6 old batteries.
  3. DYMO LabelManager 160 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/1
    • To open the cartridge compartment, simply lift on the front of the device.
  4. DYMO LabelManager 160 Keyboard Replacement: 4 단계, 이미지 1/2 DYMO LabelManager 160 Keyboard Replacement: 4 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove the four 1.3mm screws from the cartridge compartment and two 1.2mm screws from the battery compartment.
  5. DYMO LabelManager 160 Keyboard Replacement: 5 단계, 이미지 1/1
    • Using a spudger or other tool, lift and remove the front of the device. This should be done all around the device to ensure the two parts split correctly.
  6. DYMO LabelManager 160 Keyboard Replacement: 6 단계, 이미지 1/3 DYMO LabelManager 160 Keyboard Replacement: 6 단계, 이미지 2/3 DYMO LabelManager 160 Keyboard Replacement: 6 단계, 이미지 3/3
    • Gently remove the rubber keyboard from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Matthew Jenkins
회원 가입일: 01/27/16
259 평판
안내서 2개 작성하였습니다
University of Alabama, Team 1-4, Sydow campbell Spring 2016 University of Alabama, Team 1-4, Sydow campbell Spring 2016 회원
UA-SYDOW CAMPBELL-S16S1G4
4 회원들
안내서 4개 작성하였습니다
댓글 3개
Group 9: Over all looks great. Screwdriver at top of page should be under tools not parts.
In Step 4 the screws in the second picture 2x 1.2mm should be circled in orange and should be a separate bullet with appropriate coloring.
Possibly add a picture using the spudger, so the user knows exactly where they need to pry.
Fantastic lighting and clear pictures!
Zachary Parker - 답글
Where do I get a replacement key boars
willow williams - 답글
Where did you obtain the parts from as I am having difficulty
Tommy Taylor - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 16
전체 시간: 1,858
