주요 콘텐츠로 건너뛰기
DYMO LabelPOINT 100 Rubber Transport Roller Replacement
필요한 것
  1. DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Rear Panel: 1 단계, 이미지 1/3 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Rear Panel: 1 단계, 이미지 2/3 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Rear Panel: 1 단계, 이미지 3/3
    • Slide the panel release button.
    • Lift the panel.
  2. DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Label Tape Cassette: 2 단계, 이미지 1/2 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Label Tape Cassette: 2 단계, 이미지 2/2
    • Firmly press the cartridge release button with your finger.
    • You may need to hold the cassette and/or entire device still while pressing the button.
    • Lift the label tape cassette out of the device.
  3. DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Screws To the Acess Panel: 3 단계, 이미지 1/3 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Screws To the Acess Panel: 3 단계, 이미지 2/3 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Screws To the Acess Panel: 3 단계, 이미지 3/3
    • Use Phillips #00 screwdriver to remove three screws
    • Remove blade cutter
    • Use Phillips #00 screwdriver to remove remaining two screws from the battery compartment
  4. DYMO LabelPOINT 100 Rubber Transport Roller Replacement: 4 단계, 이미지 1/2 DYMO LabelPOINT 100 Rubber Transport Roller Replacement: 4 단계, 이미지 2/2
    • Gently pull the access panel up to separate from the device
    • Some electrical wiring will be exposed and will not detach. Be careful not to damage any electrical wiring when removing access panel.
  5. DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Back Panel: 5 단계, 이미지 1/3 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Back Panel: 5 단계, 이미지 2/3 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Back Panel: 5 단계, 이미지 3/3
    • Use Phillips #00 screwdriver to remove six screws
    • Slowly separate back panel
    • Gears attached to the back panel are not secured and have a tendency to fall out. This will cause difficulty when reassembling
  6. DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Rubber Transport Roller: 6 단계, 이미지 1/2 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Rubber Transport Roller: 6 단계, 이미지 2/2
    • Gently pull rubber transport roller up to remove
    • Replace rubber transport roller
결론
Deborah Canas
회원 가입일: 09/25/14
122 평판
안내서 1개 작성함
USF Tampa, Team 5-2, Mcgee Fall 2014 USF Tampa, Team 5-2, Mcgee Fall 2014 회원
USFT-MCGEE-F14S5G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 8
전체 시간: 1,246
