주요 콘텐츠로 건너뛰기
DYMO LabelWriter 450 Back Plate Replacement
필요한 것
  1. DYMO LabelWriter 450 Back Plate Replacement, Back Plate: 1 단계, 이미지 1/3 DYMO LabelWriter 450 Back Plate Replacement, Back Plate: 1 단계, 이미지 2/3 DYMO LabelWriter 450 Back Plate Replacement, Back Plate: 1 단계, 이미지 3/3
    • Make sure the device is unplugged. Then, turn over the device so that the label is readable.
    • Remove the two 15.7mm screws on the top of the device first, and then the two 26.5mm screws on the bottom (they are in the smaller holes and larger holes respectively) using a Phillips #1 screwdriver.
    • You need a spudger to orient the bottom screws so that they can be removed.
  2. DYMO LabelWriter 450 Back Plate Replacement: 2 단계, 이미지 1/2 DYMO LabelWriter 450 Back Plate Replacement: 2 단계, 이미지 2/2
    • Once the Back Plate has been unscrewed, you will see the components from the top of the device plugged into the motherboard. You will only have 1-2 inches of clearance to unplug the components from the motherboard.
    • There are four components to unplug: the power cable connector, the two small no-fuss ribbon cable connectors, and the large no-fuss ribbon cable connector. The order does not matter.
    • This device has a blade located within the front panel. When handling the device, be careful not to touch the blade.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jared Finkel
회원 가입일: 10/09/18
649 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G4, Leahy Fall 2018 USF Tampa, Team S1-G4, Leahy Fall 2018 회원
USFT-LEAHY-F18S1G4
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 19
전체 시간: 1,229
