주요 콘텐츠로 건너뛰기
Daewoo DWC LDC1412S Water pump replacement Replacement
필요한 것
  1. Daewoo DWC LDC1412S Water pump replacement Replacement, Water pump replacement: 1 단계, 이미지 1/1
    • Turn the washing machine on it s back
  2. Daewoo DWC LDC1412S Water pump replacement Replacement: 2 단계, 이미지 1/2 Daewoo DWC LDC1412S Water pump replacement Replacement: 2 단계, 이미지 2/2
    • Unscrew the 2 screw that keep the pump in place
    • You can now gently tear down the pump
  3. Daewoo DWC LDC1412S Water pump replacement Replacement: 3 단계, 이미지 1/1
    • Compare your actual pump with the spare you found BEFORE dismounting pipes !
    • Seems ok ? Let s go forward !
  4. Daewoo DWC LDC1412S Water pump replacement Replacement: 4 단계, 이미지 1/2 Daewoo DWC LDC1412S Water pump replacement Replacement: 4 단계, 이미지 2/2
    • Dismount pipes by pressing steel rings and moving then out of range of the pump
    • Do this for all pipes connected on the pump
  5. Daewoo DWC LDC1412S Water pump replacement Replacement: 5 단계, 이미지 1/1
    • Pipes are now disconnected. Let's go for electrical connections
  6. Daewoo DWC LDC1412S Water pump replacement Replacement: 6 단계, 이미지 1/1
    • Disconnect both electro pump. Check were is white wire and black wire on each !!
  7. Daewoo DWC LDC1412S Water pump replacement Replacement: 7 단계, 이미지 1/1
    • Move last evacuation pipe on the new part
    • ...you can know mount the new part and try your new pump !!
결론
다른 2명이 해당 안내서를 완성하였습니다.
hellotheworld
회원 가입일: 12/06/14
191 평판
안내서 1개 작성함
댓글 한 개
Thanks, this saved me heaps of money!!!
Brendan Innes - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 28
30일 전: 61
전체 시간: 3,523
