주요 콘텐츠로 건너뛰기
Daisy Model 10 Carbine Firing Mechanism Replacement
필요한 것
  1. Daisy Model 10 Carbine Firing Mechanism Replacement, Removing Screws: 1 단계, 이미지 1/3 Daisy Model 10 Carbine Firing Mechanism Replacement, Removing Screws: 1 단계, 이미지 2/3 Daisy Model 10 Carbine Firing Mechanism Replacement, Removing Screws: 1 단계, 이미지 3/3
    • Make sure the safety is on!
    • Place the carbine with the saddle ring and leather thong facing upwards.
    • Locate the screw head on the cocking lever.
    • There should be one on either side of the saddle ring and one on the cocking lever assembly.
    • Place a #2 Phillips Screwdriver in the 11/16ths of an inch, matte black screw on the cocking lever assembly. Twist with a counter-clockwise motion.
    • Completely remove the screws.
    • Be wary of the black washers on the other side of the Carbine. Be sure to keep track of them once they fall out after the screws are removed
  2. Daisy Model 10 Carbine Firing Mechanism Replacement, Removing the Lever: 2 단계, 이미지 1/2 Daisy Model 10 Carbine Firing Mechanism Replacement, Removing the Lever: 2 단계, 이미지 2/2
    • Remove the cocking lever by placing your dominant hand’s fingers through the cocking lever handle.
    • With your fingers in the handle, slide the lever towards the butt of the carbine.
    • Finally, pull the cocking lever and carbine in opposite directions to replace the cocking lever.
  3. Daisy Model 10 Carbine Firing Mechanism Replacement, Removing Side Screws: 3 단계, 이미지 1/2 Daisy Model 10 Carbine Firing Mechanism Replacement, Removing Side Screws: 3 단계, 이미지 2/2
    • Once the cocking lever is removed, place the carbine with the saddle ring facing upwards.
    • Locate the screws on either side of the saddle ring.
    • Using a #2 Phillips Screwdriver, twist in a counter-clockwise motion.
    • Completely remove the two screws.
    • Be wary of the two washers on the other side of the Carbine. Be sure to keep track of them once they fall out after the screws are removed
  4. Daisy Model 10 Carbine Firing Mechanism Replacement, Removing Top Screw: 4 단계, 이미지 1/2 Daisy Model 10 Carbine Firing Mechanism Replacement, Removing Top Screw: 4 단계, 이미지 2/2
    • Now rotate your carbine so the top of the carbine is visible.
    • Locate the screw located above the saddle ring where the black metal meets the wooden butt.
    • Using the same #2 Phillips Screwdriver, twist in a counter-clockwise motion.
    • Completely remove the screw.
    • Be wary that this screw is a different length, and that there is no washer attached to it.
  5. Daisy Model 10 Carbine Firing Mechanism Replacement, Removing the Butt: 5 단계, 이미지 1/2 Daisy Model 10 Carbine Firing Mechanism Replacement, Removing the Butt: 5 단계, 이미지 2/2
    • Place your dominant hand on the wooden butt and your other hand on the metal barrel.
    • Slide the butt away from the Carbine until it is free of the metal tongs.
    • The butt will not slide out quickly. The metal tongs grip the butt so that it is a tight fit.
  6. Daisy Model 10 Carbine Firing Mechanism Replacement, Remove the Firing Mechanism: 6 단계, 이미지 1/3 Daisy Model 10 Carbine Firing Mechanism Replacement, Remove the Firing Mechanism: 6 단계, 이미지 2/3 Daisy Model 10 Carbine Firing Mechanism Replacement, Remove the Firing Mechanism: 6 단계, 이미지 3/3
    • Wiggling the firing mechanism and pull it out of the back opening of the carbine.
    • There is oil on the firing mechanism and it may be slippery.
    • The firing mechanism may take some maneuvering and time to get out of the gun.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Trelawney Bullis
회원 가입일: 10/12/14
488 평판
안내서 3개 작성하였습니다
Cal Poly, Team 6-20, Maness Fall 2014 Cal Poly, Team 6-20, Maness Fall 2014 회원
CPSU-MANESS-F14S6G20
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 21
전체 시간: 10,627
