주요 콘텐츠로 건너뛰기
Dashcam DOD LS300W Battery Replacement
필요한 것
  1. Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: 1 단계, 이미지 1/3 Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: 1 단계, 이미지 2/3 Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: 1 단계, 이미지 3/3
    • Using an opening tool, pry open the seam on the bottom of the dash cam to separate the two parts of the device.
  2. Dashcam DOD LS300W Battery Replacement: 2 단계, 이미지 1/2 Dashcam DOD LS300W Battery Replacement: 2 단계, 이미지 2/2
    • Notice the connection of + and - on the top left side of the inside of the dash cam. Make note of this as it will be important to remember when you solder on the new battery.
    • Desolder the old battery. This is a 250mAh.
  3. Dashcam DOD LS300W Battery Replacement: 3 단계, 이미지 1/3 Dashcam DOD LS300W Battery Replacement: 3 단계, 이미지 2/3 Dashcam DOD LS300W Battery Replacement: 3 단계, 이미지 3/3
    • The new battery is 400mAh. and fits just in the battery location.
    • Solder in the new battery.
    • Then place the new battery into the space previously occupied by the old battery.
    • See the difference between old and new battery.
    • Be careful to solder the positive side of the new battery into the same spot that the old battery was soldered into.
  4. Dashcam DOD LS300W Battery Replacement: 4 단계, 이미지 1/1
    • Put the dashcam back together.
    • Charge the battery to the full level, and you are ready to go.
결론
Once again, thank you for checking out this guide and I hope it helped!
다른 2명이 해당 안내서를 완성하였습니다.
Pierre
회원 가입일: 04/02/13
542 평판
안내서 3개 작성하였습니다
댓글 2개
Hi mate, where did you buy the replacement battery from? I'm having trouble finding something online? blackdogwood@bigpond.com
Cheers,
Russell Edwards - 답글
Hi Russell, I found this battery on Ebay.
Good luck.
Cheers.
Pierre - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 29
전체 시간: 6,352
