주요 콘텐츠로 건너뛰기
Datawind Ubislate 7ci Rear Facing Camera Replacement
필요한 것
  1. Datawind Ubislate 7ci Rear Facing Camera Replacement, Finding a work space: 1 단계, 이미지 1개 중 1개
    • Be sure to repair your device on a clean surface so you are less likely to lose small parts.
  2. Datawind Ubislate 7ci Rear Facing Camera Replacement, Pry open your tablet: 2 단계, 이미지 2개 중 1개 Datawind Ubislate 7ci Rear Facing Camera Replacement, Pry open your tablet: 2 단계, 이미지 2개 중 2개
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated your device should look like this.
    • (HINT: be careful of the device's small wiring when separating the two halves.)
  3. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the tape around the camera: 3 단계, 이미지 2개 중 1개 Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the tape around the camera: 3 단계, 이미지 2개 중 2개
    • Remove the black tape that is circled.
    • The camera is circled in this picture.
  4. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the camera: 4 단계, 이미지 2개 중 1개 Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the camera: 4 단계, 이미지 2개 중 2개
    • Carefully remove the camera from its housing.
  5. Datawind Ubislate 7ci Rear Facing Camera Replacement, Inserting the Replacement Camera: 5 단계, 이미지 2개 중 1개 Datawind Ubislate 7ci Rear Facing Camera Replacement, Inserting the Replacement Camera: 5 단계, 이미지 2개 중 2개
    • Slide the new camera into its housing carefully.
    • it should look like the second picture when you are finished
  6. Datawind Ubislate 7ci Rear Facing Camera Replacement, Closing the Tablet: 6 단계, 이미지 1개 중 1개
    • Press the back cover of the tablet on firmly until it clicks
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Mekides
회원 가입일: 10/20/14
40 평판
안내서 3개를 작성함
UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S6G3
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 363
