주요 콘텐츠로 건너뛰기
De' Longhi CTOV 2103- AZ
필요한 것
  1. De' Longhi CTOV 2103- AZ, Pull the lever: 1 단계, 이미지 1/3 De' Longhi CTOV 2103- AZ, Pull the lever: 1 단계, 이미지 2/3 De' Longhi CTOV 2103- AZ, Pull the lever: 1 단계, 이미지 3/3
    • First unplug the cable. ...Pull off the lever, it is snapped in.
    • Pull out the drawer.
    • Now clean it with a vacuum.
    • On the underside are 4 screws Torx 10 resistant visible - in each corner one.
  2. De' Longhi CTOV 2103- AZ, Screw: 2 단계, 이미지 1/2 De' Longhi CTOV 2103- AZ, Screw: 2 단계, 이미지 2/2
    • Detail of the screw
  3. De' Longhi CTOV 2103- AZ, Housing chrome plastic ring: 3 단계, 이미지 1/3 De' Longhi CTOV 2103- AZ, Housing chrome plastic ring: 3 단계, 이미지 2/3 De' Longhi CTOV 2103- AZ, Housing chrome plastic ring: 3 단계, 이미지 3/3
    • here you have two pictures of the housing and the chrome plastic frame.
  4. De' Longhi CTOV 2103- AZ, Lever: 4 단계, 이미지 1/2 De' Longhi CTOV 2103- AZ, Lever: 4 단계, 이미지 2/2
    • Here you have details of the lever and how it is snapped in the mechanic.
    • This shows you how to unlock it when you dismantle the housing. Good luck. ;)
  5. De' Longhi CTOV 2103- AZ, Tempeaturesensor: 5 단계, 이미지 1/2 De' Longhi CTOV 2103- AZ, Tempeaturesensor: 5 단계, 이미지 2/2
    • Detail of the Sensor: It is the little black pearl at the black hoses which is strapped to the white hose.
  6. De' Longhi CTOV 2103- AZ: 6 단계, 이미지 1/3 De' Longhi CTOV 2103- AZ: 6 단계, 이미지 2/3 De' Longhi CTOV 2103- AZ: 6 단계, 이미지 3/3
    • The connector from the main platine to the switch platine.
  7. De' Longhi CTOV 2103- AZ: 7 단계, 이미지 1/3 De' Longhi CTOV 2103- AZ: 7 단계, 이미지 2/3 De' Longhi CTOV 2103- AZ: 7 단계, 이미지 3/3
    • Details of the plug and the bottom part after disassembly.
    • Where to find the plug for the yellow ground wire i show you in the next step. :)
  8. De' Longhi CTOV 2103- AZ: 8 단계, 이미지 1/2 De' Longhi CTOV 2103- AZ: 8 단계, 이미지 2/2
    • here you can see where the yellow cable belongs to.
  9. De' Longhi CTOV 2103- AZ, Reassembly: 9 단계, 이미지 1/3 De' Longhi CTOV 2103- AZ, Reassembly: 9 단계, 이미지 2/3 De' Longhi CTOV 2103- AZ, Reassembly: 9 단계, 이미지 3/3
    • Reassembly: Putt all cables at the right places, don't forget the yellow cable at the housing !!!
    • Look at the picture how to fit in the metal notch in the right place !
  10. De' Longhi CTOV 2103- AZ: 10 단계, 이미지 1/3 De' Longhi CTOV 2103- AZ: 10 단계, 이미지 2/3 De' Longhi CTOV 2103- AZ: 10 단계, 이미지 3/3
    • Here the notch is in the right place.
    • Do NOT forget to make an insulation test. Check the wiring with a multimeter.
    • Made in China.
    • Hope it was fun and may the pictures help you. Greets. :)
결론
다른 2명이 해당 안내서를 완성하였습니다.
Schwarzstein
회원 가입일: 07/15/13
2,813 평판
안내서 13개 작성하였습니다
댓글 2개
The lever broke on my toaster. And it's difficult to glue it.
skan - 답글
My daughter toasted a piece of bread but the bread burned and caught fire. I've opened the toaster, and see no fire-damage. Although, it is impossible to toast because the lever won't stay down.
Dieter Troubleyn - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 34
전체 시간: 2,439
