소개
It may be that the pump no longer works properly and builds up the pressure sufficiently. Often a valve ball inside the pump is defective, you may be able to replace it. But it may also be that the solenoid coil is no longer working. Pump Ulka EP5GW is not very expensive and replacement is quite simple.
필요한 것
Remove all attachments such as water tank, pulp drawer, brew group.
Turn the machine with the back facing you.
Remove five Torx T20 security screws.
Push the side panel back about 1.5 cm.
Lift off the panel.
The following compononents are exposed:
Heater
Expansion chamber
Gear drive
Steam valve
Work through the steps in reverse order to reassemble your device.
다음 번역가들에게 특별히 감사 드립니다:
100%
oldturkey03님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
