주요 콘텐츠로 건너뛰기
DeLonghi ESAM xxxx - Test Mode
  1. DeLonghi ESAM  xxxx - Test Mode, Activate Test Mode: 1 단계, 이미지 2개 중 1개 DeLonghi ESAM  xxxx - Test Mode, Activate Test Mode: 1 단계, 이미지 2개 중 2개
    • Pull the plug. Switch on rear side is in position "On".
    • Press and hold both keys for "one cup" and "steam".
    • Reconnect the plug.
    • LEDs light up. When they are off again, the machine is in test mode. Release the two keys.
    • If there is no water in the reservoir or not all drawers are inserted correctly, corresponding LEDs will light up.
  2. DeLonghi ESAM  xxxx - Test Mode, Motor Test: 2 단계, 이미지 2개 중 1개 DeLonghi ESAM  xxxx - Test Mode, Motor Test: 2 단계, 이미지 2개 중 2개
    • Press the key "one cup". The motor should drive down. If it reaches the lower end position the correspondending LED will light up.
    • Press the key two cups". The motor should drive upwards. If it reaches the upper end position the correspondending LED will light up.
    • Tip: the brewing unit has to be in the right start position for correct function. It's a good idea to take a foto or mark the position.
    • If the lower four LEDs light up in sequence during later operation, the start position has not yet been set correctly. Take out the brewing unit and close the service door. Press the "one cup" and "two cups" buttons simultaneously, the motor will automatically search for the right position. Put the brewing unit back in.
  3. DeLonghi ESAM  xxxx - Test Mode, Pump Test: 3 단계, 이미지 1개 중 1개
    • Press the "steam" key. The pump should be activated. If the steam wand is opened the water should flow.
  4. DeLonghi ESAM  xxxx - Test Mode, Grinder Test: 4 단계, 이미지 1개 중 1개
    • Press the "ECO" key. The grinder should be activated.
  5. DeLonghi ESAM  xxxx - Test Mode, Heater Test: 5 단계, 이미지 1개 중 1개
    • Press the "Rinse" key. One LED should light up and the heater should be activated. If it reaches the end temperature, the LED goes out.
  6. DeLonghi ESAM  xxxx - Test Mode: 6 단계, 이미지 1개 중 1개
    • Pull the plug again to leave the test mode.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
VauWeh
회원 가입일: 10/19/15
297,278 평판
안내서 303개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 92
지난 30일: 357
전체 시간: 18,564
